Home > Technical (L322) > Navcoder |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35264 |
http://www.navcoder.com/ ... - .- -.
15th Jul 2013 7:54am |
Reformed Member Since: 09 Oct 2010 Location: South Posts: 471 |
I am sure I still have my usb interface from when I owned my Rangie, if your intrested? I wouldnt ask for much, will see if I can find it. PM me if your interested. Reformed |
15th Jul 2013 7:11pm |
kay323 Member Since: 08 May 2012 Location: London Posts: 55 |
I have a USB one |
18th Jul 2013 8:58pm |
Ash_vogue Member Since: 25 Mar 2013 Location: Uk Posts: 14 |
Where did you get that from? |
18th Jul 2013 9:11pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6407 |
AFAIK, the only way to connect up the PC with navcoder installed on it is to use the Resler USB or Serial interface from here:
18th Jul 2013 11:22pm |
I got a cable from BMW cables on eBay. It was listed as working with a few bits of software, including navcoder. Came with some cdr's with BMW tis software and Ebas I believe, but I didn't use that. £20 something if I remember right. 2011 Range Rover Vogue SE 4.4 TDV8
19th Jul 2013 4:07am |
I have the same one as the link above. Where abouts are you based, maybe you can borrow mine if local |
20th Jul 2013 1:11am |
Thanks for the offer, I live in Leicestershire, I don't mind buying one, just want to get one that will work and is easy to use. Is the one from the link above just plug and play? |
20th Jul 2013 8:40pm |
Winchester101 Member Since: 13 Jun 2013 Location: Essex Posts: 236 |
hi kay
8th Feb 2014 10:05pm |
thatgirl101 Member Since: 28 Feb 2014 Location: London Posts: 45 |
Hi all, just bought a cable from ebay - but where do I connect it?! |
31st May 2014 4:13pm |
It goes in the obd2 connector that is in the little compartment near you right knee as you are driving. It's a few inches under the light switch. There is a black cover on it that you will have to pull down.
31st May 2014 6:30pm |
31st May 2014 6:38pm |
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2938 |
Good luck with the obd cable. I bought one and I didn't work. I then emailed the navcoder guy and he said not to use the obd port. I ended up buying a serial port version in the end and soldering the cables directly into the can bus line |
2nd Jun 2014 7:11pm |
Agree with Noddy, from the navcoder site:
http://navcoder.com As I mentioned above, I have used the resler interface with success. . Experience is the only genuine knowledge, but as time passes, I have forgotten more than I can remember Volvo V70 P2 2006 2.4 Petrol 170bhp Estate SE MG Midget Mk1 1962 Previous: L322 Range Rover TDV8 3.6 2008; L322 Range Rover TD6 3.0 2002; P38A Range Rover V8 1999 |
3rd Jun 2014 12:14am |
