Home > Technical (L322) > Headlight wipers
Headlight wipers
Hi Guys
Just come outthe house and noticed one of my headlight wipers is stuck in the vertical position. I'm guessing it happened yesterday on my way home from work when I used the washers. They are frozen as well so a big waste. Is there away to reset the wipers or should force just be used to persuade it back?[/url]
Post #42867 20th Dec 2010 2:42pm
loads on this if you do a search.... Thumbs Up ... - .- -.
Post #42868 20th Dec 2010 2:46pm
Ok will do. Bit hard on my phone. Just waiting to give blood.
Post #42869 20th Dec 2010 2:51pm
Avi
2006 Range Rover Vogue Td6 Alveston Red
I'm feeling festive:
http://www.fullfatrr.com/wiki/Headlight_Wiper
Post #42870 20th Dec 2010 2:56pm
Cheers for that! Does it matter if it's halfway or all the way up?
Post #42872 20th Dec 2010 3:13pm
Mr Tee
Doesn't matter at all, just did this on mine yesterday, worked a treat!
Post #42873 20th Dec 2010 3:19pm
Hmmm
Reset procedure of pulling fuse 28 with car off not working for me:
RHS wiper works, LHS wiper not moving (stuck at angle of @ 20 degrees from horizontal), no wash on either side.
(Yes, remembered to turn on lights)
No faults from IID Tool I can identify as relating to this....
Any suggestions Question Which control module looks after this Question .
Post #198801 14th Jul 2013 2:43pm
headlamp wash is on the BPM-Body Processor module Tim.. ... - .- -.
Post #198807 14th Jul 2013 4:13pm
Thanks Stan
Doesn't appear to be anything to fiddle with using IIDTool either with faults or config Sad .
Post #198813 14th Jul 2013 5:26pm
the old battery disconnection then.. ... - .- -.
Post #198836 14th Jul 2013 8:12pm
Thumbs Up .
Post #198839 14th Jul 2013 8:35pm
Update, finally tried a battery disconnect on this today whilst doing my new radiator.
Upon reconnecting, the offending headlight wiper sprang into life and came to rest in the vertical position!
So disconnected again, and this time it settled back to normal resting position.
Haven't tried the wash wipe yet, not patient enough to keep waiting the 3 minutes! .
Post #211466 21st Sep 2013 3:02pm
a reboot works wonders... Laughing ... - .- -.
Post #211469 21st Sep 2013 3:12pm
Just to confirm, wipers and washers back in operation after battery disconnection procedure, hopeful they stay that way until MOT in July Wink .
Post #234086 11th Jan 2014 12:58pm
doclees
United States 2004 Range Rover HSE 4.4 V8 Java Black
I know this is an old thread. Just adding my experience. I tried the pull fuse, start car, put fuse back in trick but didn't work even after hours of wait. Left it out for over 24 hours and it worked.
Post #401619 22nd Aug 2016 8:40pm
