Home > Technical (L322) > Locking after moving off and remotely opening windows on fob |
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2938 |
I set mine to lock after driving off using RSW allcomms. It doesn't open on taking the key out though. I'd be interested in having that function |
12th Jul 2013 6:58am |
There are settings in the CCF that allow for lock on drive-of (and you can even select certain speeds) and unlock on removing the key etc.. You need a Faultmate, IID, T4 Testbook etc. tool to do that (not sure about the capabilities of them apart from the Faultmate).
12th Jul 2013 7:18am |
markcartlidge Member Since: 18 Mar 2013 Location: Nr Winslow, Buckinghamshire Posts: 120 |
I have used my IID Tool to change the "speed rlated locking" after finding the right key and set "single point entry" but I dont think it allows for unlock on key removal? unless it is on "Lazy unlock from door key" See below.
12th Jul 2013 8:38am |
I haven't got any experience with the IID, I use the Faultmate for all my changes. I set it at 8 mph. From memory (I haven't played with the Faultmate for a long time now) you can set it for 0 (when you select drive it locks the doors), 4, 8, 12 etc. Works like a charm on mine.
12th Jul 2013 8:42am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35247 |
''Lazy unlock from door key'' suggests that turning the key in the door does the lazy unlock.. ... - .- -.
12th Jul 2013 9:01am |
Rich86 Member Since: 10 Mar 2013 Location: Surrey Posts: 509 |
the key opens the windows when you turn it left on the drivers door but doesnt remotely open the windows but used to... 2009 Vogue TDV8 Nara Bronze
12th Jul 2013 3:03pm |
Sounds like it lost the settings. Suggest to get someone with a diagnostic compu to set them again. Or did you change keys in the mean time ?? Not all keys have the same settings. MY 2010 5.0 SC Galway green and sand interior!!
12th Jul 2013 3:33pm |
Have tried both keys and neither works...
13th Jul 2013 12:25pm |
