Home > Maintenance & Mods (L322) > Spare Wheel Lift - Fitting Pics
TugRR
Just a few pics of fitting the Spare Wheel Lift if your car doesn't have one fitted.
PARTS:
Spare Wheel Bracket
Bolts x 2
Tailgate prop
TOOLS:
8mm Allen Key
WARNING:
If you've never handled the spare wheel before, take GREAT CARE removing it from the car due to it's WEIGHT and AWKWARD POSITION
This is what you have for starters - the two fixing holes either side of the jack. Remove the jack.
Unravel the lifting straps and fit the strap end fixings "upside down" onto the fixing holes - this makes more sense doing it than describing it. Fit the two bolts and tighten with the allen key.
Remove yourself from the boot and close the tailgate to fit the handle to the lower tailgate latch. Open the tailgate.
Slide your spare wheel onto the straps and trial lowering the spare wheel into the well by lifting the lower tailgate. Do this carefully as you won't get the position correct until after a few goes and you don't want to damage your compressor . . .
Raise the tailgate and ravel the straps to the lifting handle. Place the lifting handle at the rear of the spare wheel.
It's got to be one of the most beneficial mods you can do to your car and even if you don't change the wheel yourself, I reckon it will make the guy who does it smile -
Thumbs Up Where do you go after one of these . . . ?
Post #198346 10th Jul 2013 1:56pm
Baron
United Kingdom 2011 Range Rover Vogue TDV8 Baltic Blue
Top info Thumbs Up this'll help me a lot.
Top man and many thanks for posting this. 4.4 TDV8 Vogue Baltic Blue MY11
Post #198349 10th Jul 2013 2:08pm
Idealy i think the tyre needs to be 1-2" onto the lower tailgate as you lower and the compressor in the 2005=> models isnt that sensitive to the odd little knock from a wheel if your gentle Smile
Also take it as a time to check for dampness down there and hoover out any cack that has built up as left for long enough the dirt starts to stick and weld itself in almost Sad FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #198355 10th Jul 2013 2:57pm
TugRR
"Check for dampness down there" Shocked
But seriously, you're right KP - I had some (ahem). I'm open minded as to the cause, however, as the latch plate of the lower tailgate was so loose the upper tailgate wouldn't seat or seal on the lower correctly. Tightened up now and all snug -
Post #198362 10th Jul 2013 4:33pm
Very good. Now clean your spare tyre Very Happy .
Post #198367 10th Jul 2013 5:01pm
Good write up Thumbs Up
On another note.. I hate seeing lead weights hammered on to the side of alloys. Should be stick on weights only IMO.
The bracket for the weight will eat into the wheel eventually. Previously..
Post #198376 10th Jul 2013 6:24pm
TugRR
^^ Censored off - it'll get dirty anyway . . .
^ Agreed - weights were factory fitted, - it's never been out before !
Post #198387 10th Jul 2013 7:25pm
roger 47
United Kingdom 2017 Range Rover Autobiography SDV8 Fuji White
That's a useful bit of kit, who supplies it and is it a LR part, if so what is the part number? '88 RR Classic, '90 Classic, '93 Classic, '02 Discovery TD5, '55 Discovery 3, '01 P38 4.6, '06 L322 Vogue TD6, 2012 L322 Vogue TDV8, 2017 L405 Autobiography
Wife. '01 Freelander, '07 Freelander 2.
Post #198447 11th Jul 2013 11:49am
VaguelyVogue
United Kingdom 2006 Range Rover Vogue Td6 Buckingham Blue
It's discussed here http://www.fullfatrr.com/forum/topic19435.html
Post #198448 11th Jul 2013 11:51am
TheAllSeeingPie
United Kingdom 2007 Range Rover Supercharged Supercharged Java Black
I've found it's a bit of a funny fit with a MY2007 car. The handle doesn't quite fit in as snugly into the wheel well as yours does. A bit of faffing and it does fit to the side and overall it makes getting tyres in and out a LOT easier.
07 Supercharged - Still breaking her in!
Boot soundproofing part 1 - http://www.fullfatrr.com/forum/topic15612.html
Custom exhaust - http://www.fullfatrr.com/forum/topic15296.html
18" wheels for Brembo equipped cars - http://www.fullfatrr.com/forum/topic15052.html
Post #198456 11th Jul 2013 12:39pm
TugRR
ASP - Tyre diameter perhaps ?
I presume your SC is on the standard 20" wheels, so there may be a slight difference in overall diameter - taking into account tyre aspect ratio . . .
All good, though !
Post #198461 11th Jul 2013 1:17pm
ebajema
Until recently I never knew you could use the straps and bracket in such a smart way. I was always tugging on the bloody things myself Sad And I'm sure it is not in the manual (although I will check when I have the car available again !!) Thanks for the excellent write-up. MY 2010 5.0 SC Galway green and sand interior!!
Post #198462 11th Jul 2013 1:46pm
TugRR
Genius piece of design, I reckon -
Post #198473 11th Jul 2013 3:32pm
philbathurst
United Kingdom 2016 Range Rover Vogue SE TDV6 Montalcino Red
never realised how heavy the spare wheel was and how tricky to get out
dan supplied the parts fitted in 10 mins great addition Cool
why did fords stop fitting this ? you could argue they created a health & safety issue Shocked
Post #199350 18th Jul 2013 7:37am
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
Funny I've had my wheel in and out several times and never found it particularly heavy. That said my G/F is insured so it would probably be a decent investment anyhow- She's far too handy to call the RAC!
Bow down
EDIT: Nice writeup BTW, Tug!
Post #199352 18th Jul 2013 7:43am
