Home > Maintenance & Mods (L322) > Changing front pads TD6
mrblonde
United Kingdom 2003 Range Rover Vogue Td6 Adriatic Blue
When I change the front pads and wear sensor on my TD6 (2003), will I need to reset the alarm/warning light on the dash?
And will the brakes need bleeding if I'm only changing the pads?
Cheers
Post #197998 8th Jul 2013 12:27pm
I don't know about the warning light.
They shouldn't need bleeding.
Post #197999 8th Jul 2013 12:33pm
rjp996
United Kingdom 2003 Range Rover Vogue Td6 Buckingham Blue
I've changed my front brake sensor the other week. No reset of warning light needed (on l322 TD6), but it did not go out straight away but did after I had driven it for a few mins (had same thing happen onto old x5).
Post #198038 8th Jul 2013 4:33pm
ahebron
New Zealand
As long as you do it correctly you should not need to bleed the brakes.
Adrian VW Amarok 2014 Highline auto
Post #198321 10th Jul 2013 10:25am
mrblonde
Cheers all, light went out after about 40 miles (week driving for me), and brakes feel so much smoother and controlled. Be doing the rears in a couple of weeks
Thanks again
Post #198323 10th Jul 2013 10:38am
