Home > Technical (L322) > Mirrors fold in and back out |
The mirrors have lost there "home" position and need to have them reset. Can't remember how that is done but you don't need to take them apart. Suggest to do a search on the forum. MY 2010 5.0 SC Galway green and sand interior!!
8th Jul 2013 4:30pm |
jumbocar Member Since: 08 Jul 2013 Location: London Posts: 22 |
Have noticed that the drivers side attempts to close further than it should- it hits the holder and then both mirrors fold back out
8th Jul 2013 4:36pm |
SoggyBottoms Member Since: 05 May 2012 Location: Northants. Posts: 456 |
mine reset when I disconnected the battery to change it |
8th Jul 2013 4:59pm |
netsonic Steve Member Since: 06 Oct 2010 Location: Sussex Posts: 165 |
Most likely culprit is the micro switch, so yes it’s an open the cover job in my view. The micro switch metal arm has either come loose or its just bent out of adjustment so it’s then a case of clipping it back or a bit of trial and error to get it bent back, needs very little adjustment to make it work. It only needs one micro switch to be out of adjustment or loose to affect both mirrors............ |
8th Jul 2013 6:18pm |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3118 |
If you double tap the button a few times it can reset IIRC. |
8th Jul 2013 10:21pm |
twhincup Member Since: 22 Feb 2012 Location: byfleet Posts: 109 |
i'm sure someone more knowledgeable will be along shortly, but when mine did this its the microswitch that needs sorting. 2007 3.0L Diesel VW Touareg SE
9th Jul 2013 9:13am |
RRVSE Member Since: 18 Apr 2009 Location: Bury Posts: 597 |
Yep, As per Dolphinboy , tap the button on the drivers door that is used to fold the mirrors twice quite quickly (can't remember if need engine running or not, but don't think it matters) and it causes the mirrors to re-calibrate . I've used it 3 times now when my mirrors went out of sync - one folded in as the other opened out and vice versa - and clicking the button twice did the trick. I does seem a bit sensitive about how quick you push the button - so if nothing happens first time, just try again , several times if required. Saves removing the casing for what might be fixed by a few seconds of clicking. Steve
10th Jul 2013 12:14am |
NormanP Member Since: 15 Mar 2013 Location: Oxford Posts: 136 |
If the double tap on the switch to reset does not work, next step (as others have said too) is the microswitch in the mirror housing. Some dirt or a bug may have got in there. The Wiki has good pics and step by step directions on how to fix - it is really easy 5 min job even for non techies like me : see http://www.fullfatrr.com/gallery/thumbnails.php?album=341 Mine kept re-opening recently but a clean of one of the microswitches sorted it. The switch didn't look obviously dirty either, but a quick squirt with an air duster seems to have sorted it and car is now back to as-new functioning. Norman
10th Jul 2013 6:16am |
Havank Member Since: 05 Apr 2007 Location: Woking - Surrey Posts: 193 |
Thanks for this topic, the mirrors have been playing up for the last month - will try the double tap during lunch time |
10th Jul 2013 7:52am |
Worth noting though that if you fold/unfold the mirrors with that switch repeatedly (I think from memory it is something like 5 times within a minute), the mechanism will time out and not work for about 5 minutes, nothing broken or wrong but it just prevents over-use (I assume in case some gremlin starts the folding in/out). It will be OK again after a few mins. Norman Current LR: L405 Vogue TDV6 (MY 2014) Aintree Green/ Ivory interior Past LR: L322 Vogue 4.4 V8 (2002); Discovery series1 V8 (1995) |
10th Jul 2013 2:35pm |
Hi
15th Jul 2013 10:39am |
would it be smug to say ............i told you so
15th Jul 2013 5:43pm |
