Home > Technical (L322) > Mirrors fold in and back out
jumbocar
2004 Range Rover Autobiography 4.4 V8 Zambezi Silver
Hi
Car is a 2004 L322
Folding mirrors worked fine but all of a sudden if you hit the button the mirrors fold in- but then back out again.
Possibility that someone pulled/ pushed the mirrors out manually on the weekend. Not sure.
Should I crack open the casing and look for the control arm? Is that the likely culprit?
Advice appreciated
Post #198023 8th Jul 2013 3:53pm
ebajema
The mirrors have lost there "home" position and need to have them reset. Can't remember how that is done but you don't need to take them apart. Suggest to do a search on the forum. MY 2010 5.0 SC Galway green and sand interior!!
Post #198027 8th Jul 2013 4:30pm
jumbocar
Have noticed that the drivers side attempts to close further than it should- it hits the holder and then both mirrors fold back out
Does that help identify most appropriate fix to attempt?
Post #198028 8th Jul 2013 4:36pm
SoggyBottoms
United Kingdom 2007 Range Rover Vogue Supercharged Zambezi Silver
mine reset when I disconnected the battery to change it
Post #198033 8th Jul 2013 4:59pm
netsonic Steve
United Kingdom 2002 Range Rover Vogue Td6 Epsom Green
Most likely culprit is the micro switch, so yes it’s an open the cover job in my view. The micro switch metal arm has either come loose or its just bent out of adjustment so it’s then a case of clipping it back or a bit of trial and error to get it bent back, needs very little adjustment to make it work. It only needs one micro switch to be out of adjustment or loose to affect both mirrors............
Post #198047 8th Jul 2013 6:18pm
Dolphinboy
If you double tap the button a few times it can reset IIRC.
Post #198105 8th Jul 2013 10:21pm
twhincup
2004 Range Rover Vogue 4.4 V8 Zambezi Silver
i'm sure someone more knowledgeable will be along shortly, but when mine did this its the microswitch that needs sorting. 2007 3.0L Diesel VW Touareg SE
2003 4.4 LPG, Vogue, Silver
Post #198149 9th Jul 2013 9:13am
RRVSE
United Kingdom 2013 Range Rover Vogue SDV8 Corris Grey
Yep, As per Dolphinboy , tap the button on the drivers door that is used to fold the mirrors twice quite quickly (can't remember if need engine running or not, but don't think it matters) and it causes the mirrors to re-calibrate . I've used it 3 times now when my mirrors went out of sync - one folded in as the other opened out and vice versa - and clicking the button twice did the trick. I does seem a bit sensitive about how quick you push the button - so if nothing happens first time, just try again , several times if required. Saves removing the casing for what might be fixed by a few seconds of clicking. Steve
Main car : FFRR L405 Vogue SDV8
Other car : Vauxhall Lotus Carlton
Past cars : FFRR L322 Vogue TD6 SE (Sept 2006 MY07) ; LandCruiser SWB ; 4-Runner ; Supras; XJS V12 LeMans
Post #198268 10th Jul 2013 12:14am
NormanP
United Kingdom 2014 Range Rover Vogue TDV6 Aintree Green
If the double tap on the switch to reset does not work, next step (as others have said too) is the microswitch in the mirror housing. Some dirt or a bug may have got in there. The Wiki has good pics and step by step directions on how to fix - it is really easy 5 min job even for non techies like me Smile : see http://www.fullfatrr.com/gallery/thumbnails.php?album=341 Mine kept re-opening recently but a clean of one of the microswitches sorted it. The switch didn't look obviously dirty either, but a quick squirt with an air duster seems to have sorted it and car is now back to as-new functioning. Norman
Current LR: L405 Vogue TDV6 (MY 2014) Aintree Green/ Ivory interior
Past LR: L322 Vogue 4.4 V8 (2002); Discovery series1 V8 (1995)
Post #198270 10th Jul 2013 6:16am
Havank
United Kingdom 2003 Range Rover Vogue Td6 Java Black
Thanks for this topic, the mirrors have been playing up for the last month - will try the double tap during lunch time
Post #198277 10th Jul 2013 7:52am
NormanP
Worth noting though that if you fold/unfold the mirrors with that switch repeatedly (I think from memory it is something like 5 times within a minute), the mechanism will time out and not work for about 5 minutes, nothing broken or wrong but it just prevents over-use (I assume in case some gremlin starts the folding in/out). It will be OK again after a few mins. Norman
Post #198345 10th Jul 2013 2:35pm
jumbocar
Hi
Just to update
Pulled off the drivers side mirror cover. Came off easily, just need to be gentle with it- prying the back cover away from front using a small screwdriver. Started at the bottom and worked my way around.
Found some spider webs, cleaned them up, then pulled out microswitch holder. The microswitch arm was detached, had snagged against the shaft. Straightened it up, reattached it and reassembled.
Working fine now
Thanks fellas
Post #198879 15th Jul 2013 10:39am
netsonic Steve
would it be smug to say ............i told you so Thumbs Up Whistle
good you got it fixed Mr. Green
Post #198939 15th Jul 2013 5:43pm
