Home > Technical (L322) > Temperature gauge rising |
KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848 |
Mine doesn't do that, so yes, I think you have a problem. |
29th Jun 2013 12:05pm |
Katash Member Since: 10 Apr 2011 Location: Hereford Posts: 700 |
Maybe the viscus fan clutch is stuck but from what I've read they usually stick on resulting in the fan running all the time, alternativly maybe the thermostat stuck closed or coolant pump not pumping. |
29th Jun 2013 1:31pm |
winslo Member Since: 12 Sep 2011 Location: Morpeth, Northumberland Posts: 135 |
Shall take into my local garage Monday morning and see what's what! |
29th Jun 2013 1:34pm |
Good idea - my bet is thermostat. |
29th Jun 2013 2:31pm |
Might have nothing to do with this but....cold ir is coldsh, well t was 11 degrees outside, but when you hit ar con it gets warmer??
29th Jun 2013 5:12pm |
Range rover is in the garage now
2nd Jul 2013 12:42pm |
EGR blanking kit is a common upgrade people do, dont think it should affect cooling. To be honest I would think even if the stat is stuck shut you would still get hot water return to headder tank.
2nd Jul 2013 1:04pm |
yes all the hoses are hot
2nd Jul 2013 1:06pm |
Think the small one is for the A/C condenser .... big one is connected to a viscous clutch arrangement IIRC .... maybe that is shot but as I said most people report when it fails it usually sticks on resulting in the RR sounding like a jumbo jet on takeoff. |
2nd Jul 2013 1:24pm |
Turn the AC off and test again as if they leave the AC on there could be jsut enough air flowing over the rad with an open thermostat to keep it cool but when loaded up with heat from a turbo as well being dumped into the water system climbing a hill and more strain on the gearbox the AC fan alone isn't enough.
2nd Jul 2013 2:54pm |
ambulancekidd Member Since: 29 Feb 2012 Location: Ayrshire Scotland Posts: 276 |
I've had this problem with every Land Rover I've had over the last 30 years (yes including my TD6 FFRR) & the cause is always exactly the same. The radiator core is blocked & no back flushing is not effective. The real answer is a new radiator & while your in there replace the thermostat as it'll probably be cooked.
2nd Jul 2013 4:38pm |
Update
2nd Jul 2013 7:03pm |
Update
1st Aug 2013 3:34pm |
