Home > Technical (L322) > Temperature gauge rising
winslo
2005 Range Rover Vogue Td6 Adriatic Blue
More advice needed
Today is the first day I've really done any distance in my new 05 td6' temp seems to sit perfect until you go up a hill and rises to about 3/4 well just before that line, then comes back down again. Also the same in traffic and I've not heard the fan cut in?
Any advice on anything I can check to see if someone has unplugged something?
Thanks in advance
Post #196814 29th Jun 2013 12:03pm
Mine doesn't do that, so yes, I think you have a problem.
Post #196815 29th Jun 2013 12:05pm
Katash
England 2007 Range Rover Supercharged 4.2 SC V8 Zermatt Silver
Maybe the viscus fan clutch is stuck but from what I've read they usually stick on resulting in the fan running all the time, alternativly maybe the thermostat stuck closed or coolant pump not pumping.
Post #196823 29th Jun 2013 1:31pm
winslo
Shall take into my local garage Monday morning and see what's what!
Post #196824 29th Jun 2013 1:34pm
Katash
Good idea - my bet is thermostat.
Post #196833 29th Jun 2013 2:31pm
winslo
Might have nothing to do with this but....cold ir is coldsh, well t was 11 degrees outside, but when you hit ar con it gets warmer??
Car has not used any water in the 200 miles I've drove nd no leaks on drive etc
I hope it's thermostat too !
Thanks again
Post #196856 29th Jun 2013 5:12pm
winslo
Range rover is in the garage now
Mechanic doesnt think it is thermostat as all the pipes are hot, and so it water coming back into header tank.
He is going to look at the thermostat cooler thing on the EGR now, he has also noticed that the car does not have a egr, it has a delete kit or blank plate or something?
Also had the car running outside his garage for an hour and temp gauge didnt move past the middle, only seems to be when going uphill and sometimes when in traffic
anything else to check?
Post #197231 2nd Jul 2013 12:42pm
Katash
EGR blanking kit is a common upgrade people do, dont think it should affect cooling. To be honest I would think even if the stat is stuck shut you would still get hot water return to headder tank.
Is the fan definatly going?
You should be able to get to rad hoses and feel the temp .... that would tell you if stat is opening.
Post #197237 2nd Jul 2013 1:04pm
winslo
yes all the hoses are hot
car sat for an hour running, there is one fan going but the noisy one you would expect to come on if the car was overheating didnt come on.
Post #197239 2nd Jul 2013 1:06pm
Katash
Think the small one is for the A/C condenser .... big one is connected to a viscous clutch arrangement IIRC .... maybe that is shot but as I said most people report when it fails it usually sticks on resulting in the RR sounding like a jumbo jet on takeoff.
Post #197244 2nd Jul 2013 1:24pm
Turn the AC off and test again as if they leave the AC on there could be jsut enough air flowing over the rad with an open thermostat to keep it cool but when loaded up with heat from a turbo as well being dumped into the water system climbing a hill and more strain on the gearbox the AC fan alone isn't enough.
TBH i have no viscous fan on mine and even during offroading up steep gradients up and down i haven't had the needle move from just a smidge below middle Smile
I bet the coolant isn't that great either so i'd flush the system first incase there is some sludge causing a loss of heat dumping ability from the radiator pack.
The coolant should be flushed every 3 years but in reality its never done as part of the service schedule, much like brake/PAS/Diff/Trans fluids that tend to get left until they are 5 years or more old and some poor sap flushes the lot and finds them looking like crud most of the time Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #197261 2nd Jul 2013 2:54pm
ambulancekidd
Scotland 2005 Range Rover Vogue Td6 Oslo Blue
I've had this problem with every Land Rover I've had over the last 30 years (yes including my TD6 FFRR) & the cause is always exactly the same. The radiator core is blocked & no back flushing is not effective. The real answer is a new radiator & while your in there replace the thermostat as it'll probably be cooked.
Not too expensive in the grand scheme of things really...Good luck.. Thumbs Up The reason women's minds are cleaner than a mans mind is that women change their minds more often!
When women say fine a mans in deep doodoo as fine has so many meanings.
Post #197278 2nd Jul 2013 4:38pm
winslo
Update
Mechanic had it out for a drive and got temp up, plugged it into snap on machine and the temperature of coolant was 71 degrees, but the gauge was nearly upto 3/4
He is trying again tomorrow so see what he finds
Post #197317 2nd Jul 2013 7:03pm
winslo
Update
Changed thermostat for new one
Changed Radiator for a used one from a 50k car
Changed Electric fan
Changed Intercooler
Changed A/C Rad
Still doing exactly the same!
Whats next? Could it be something as daft as knakered clocks? As when you first start in morning its straight onto top of blue before you even start the engine
cheers
Post #201906 1st Aug 2013 3:34pm
