Home > Technical (L322) > Headlight washers
darrenmax
Belgium 2003 Range Rover Vogue Td6 Giverny Green
Headlight washers
Did the 2006 facelift but never connected the headlamp washers, car failed mot today for this, does anyone know what diameter hose i need to fit the washers ? otherwise i have to take the bumper off to see,
Thanks 2002 td6 vogue, 06 supercharged facelift
Post #19688 9th Jun 2010 12:52pm
daveo
hi mate....slow down your making work for your self.. remove the right hand head light as you lookat them and you can access all you need ..i was told you need neww pumps and bottle to run, i have the same but nevered failed the mot for them..let me know as i would like to put my ones right
daveo V8 facelift Range Rover Autobiography 22" wheels.
Post #19704 9th Jun 2010 4:04pm
darrenmax
took the bumper off, only took 15minutes, i used a 10mm hose with a plastic reduction to fit the old hose, the right one worked fine but the left was kind of weak so i lengthened the right hand hose to the same length as the left one to even things out, now it works fine, i didnt want to remove the headlights cos they check the alignment when she goes back to the testing station tomorrow, and here in belgium theyre a bit fussy, as for the pump and bottle i cant see why you would need to change it 2002 td6 vogue, 06 supercharged facelift
Post #19722 9th Jun 2010 7:30pm
daveo
hi, when i had my conversion they said it would be extra to have these working,around £260 as i would have to have a new bottle and hi-pressure pump. it was on my to do list just more at the bottom then the top...
so you when you took the bumper and was looking at the bottle how many pumps did it have..i think they have three,windscreen,rear screen and the old head light wash...is that right ...
thanks daveo V8 facelift Range Rover Autobiography 22" wheels.
Post #19730 9th Jun 2010 8:25pm
darrenmax
yep 3 pumps, the headlights and rear wash er go around the front bumper carrier and the windscreen washers go through the engine bay , kinda weird that the rear goes so far instead of going through the engine bay, maybe its been changed for left hand drive ? 2002 td6 vogue, 06 supercharged facelift
Post #19735 9th Jun 2010 9:06pm
daveo
thanks darren, i did have a quick look when i was changing my side lights for led's, you have to take the lights out to get to them due to the conversion, buy the way..3 screews for the grill and 3 for the head light, the adjuster is not removed so allingment remains ok as when you replace the light it clips back in to the adjuster..
thanks daveo. V8 facelift Range Rover Autobiography 22" wheels.
Post #19737 9th Jun 2010 9:32pm
