Home > Technical (L322) > 2007-2009 door card panel LED lighting set up |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 |
can you see the led in these positions,are they physically there....what did you do about the air bags in the doors.. V8 facelift Range Rover Autobiography 22" wheels.
30th Jun 2013 8:33am |
Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1228 |
There are holes for the LEDs and the wiring seemed to be there, I forgot to check the LED positioning before installing. I might take a panel off today to check.
30th Jun 2013 8:47am |
TheAllSeeingPie Member Since: 18 Apr 2012 Location: Leeds Posts: 848 |
Pre-2007 the airbags are in the doors, post-2007 they are in the seat (hence the loss of upper back adjustment). So essentially you've removed your side impact airbags.
30th Jun 2013 9:32am |
Just opened up the panel and you are right the door frame has the airbags for the front doors just next to the lock pin, on the old panel there is a special membrane with netting to split when the bag detonates, the new panel does not have one due to the airbags being moved to the seats. I wonder if the newer seats could be fitted and the airbag wiring loom diverted from the door to the seat.
30th Jun 2013 9:57am |
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2938 |
Airbags where fitted as standard, have to work. |
30th Jun 2013 7:58pm |
