Home > In Car Electronics (L322) > Acceptable reading for a parasitic battery drain test? |
dirtyharry Member Since: 23 Oct 2012 Location: Ashby Magna Posts: 242 |
I carried out a parasitic battery drain test this evening. However, I would like to know what the views are as to an acceptable reading? The lowest reading I could get was 0.2 of an amp (i.e. 200mA). However, I thought I should get a reading lower than this but, despite removing each fuse one by one, I couldn't find one that would reduce it any lower and that might be causing unnecessary drainage on the battery.
26th Jun 2013 7:28pm |
Damn - not the answer I was after But I had a gut feeling it should be around the sub-50mA mark.
26th Jun 2013 7:46pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3969 |
Disconnect the cable from the Jump start post and touch one end of your multimeter to the post and the other end to the end of the cable you have just disconnected.
26th Jun 2013 7:49pm |
Cheers
26th Jun 2013 8:32pm |
28th Jun 2013 6:05am |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 797 |
fully charged battery should show about 12.7v. 13.2 sounds wrong - or was that the reading whilst still attached to the charger when the charger was showing full charge?
4th Jul 2013 6:29pm |
13.2v was when it had just had a full charge and was still attached to the charger. I've been using it for the last few days and have done 180 miles, just been out to test it - 12.26v!
5th Jul 2013 3:35pm |
i don't normally take a battery reading when the battery is still attached to a charger that is on.
5th Jul 2013 6:00pm |
If you have the original telephone installed and don't use it try pulling Fuse 22.
8th Jul 2013 10:32am |
After all that, it would appear the cause of my battery drain was the Ipod not switching itself off! Didn't have it set to "sleep" mode! Cheers
16th Jul 2013 6:39pm |
