Home > Technical (L322) > Accelerator pedal / throttle position issues
TheAllSeeingPie
United Kingdom 2007 Range Rover Supercharged Supercharged Java Black
So I was logging some data with Rev and noticed that my trottle position only ever goes to 78% and that the pedal reads 14% without any pressure and 89% with kickdown. Can anyone with an IIDTool check their values please? I've had a new pedal from Dan but that's not solved it at all. Is there something I can reset to make it read correctly?
07 Supercharged - Still breaking her in!
Boot soundproofing part 1 - http://www.fullfatrr.com/forum/topic15612.html
Custom exhaust - http://www.fullfatrr.com/forum/topic15296.html
18" wheels for Brembo equipped cars - http://www.fullfatrr.com/forum/topic15052.html
Post #196290 26th Jun 2013 6:13pm
Katash
England 2007 Range Rover Supercharged 4.2 SC V8 Zermatt Silver
Going to check now gimme 5 mins
Post #196304 26th Jun 2013 6:45pm
Katash
I got
Zero Position 12.939%
Full Position 82.733%
Kick Down 90.183% / 89.790%
I tested twice and got same readings for zero and full positions but slightly different on kickdown, probably me tho not applying the same pressure.
Hope that helps.
Post #196308 26th Jun 2013 6:56pm
TheAllSeeingPie
That's great! Could I trouble you to check throttle position as well please? Shoud be further along in the PCM engine values
Post #196310 26th Jun 2013 6:58pm
Katash
78.420% at kickdown
Post #196323 26th Jun 2013 7:20pm
TheAllSeeingPie
Hmm that's what I get. I guess that's normal, or we both have knackered throttles.
Post #196324 26th Jun 2013 7:26pm
Katash
What is your issue?
Post #196327 26th Jun 2013 7:34pm
TheAllSeeingPie
Just the fact it doesn't say it opens 100% sets off my OCD!
Post #196337 26th Jun 2013 8:10pm
GraemeC
United Kingdom 2007 Range Rover Vogue SE TDV8 Zermatt Silver
Not sure if this could happen on a RR but on a previous car it was common for the throttle not to open 100% due to the cable from the pedal to the throttle position sensor stretching.... 2007 Zermatt Silver TDV8 Vogue SE - now sold but was a great car!
Post #196339 26th Jun 2013 8:18pm
Katash
Pretty sure the throttle is fly by wire and is connected to a potentiometer
Post #196340 26th Jun 2013 8:19pm
TheAllSeeingPie
It's all fly by wire for the L322. I'm just hoping it's the OBD reading degrees open as % or something. Seems odd that the throttle body wouldn't open more than 78% or the throttle itself 90%. Unless it's a 5v scale and the actual max is not 5v or something daft ...
Post #196344 26th Jun 2013 8:37pm
Katash
Or maybe the throttle body servo can physically drive past 100% and its just calibrated that way, I wouldn't worry about it.
Post #196345 26th Jun 2013 8:40pm
