Home > Technical (L322) > Front strut replacement - in pairs? |
Ideally only replace in pairs even though the other one "May" be functioning perfectly. |
22nd Jun 2013 5:44pm |
Hi Cappo, I suggest to do both, I did and both bags looked in pretty similar (bad) condition although one bag started to leak (or at least that is what it looked like).
22nd Jun 2013 5:47pm |
Cappo Member Since: 19 Sep 2011 Location: Kent Posts: 537 |
Thanks both - just as I suspected, and yes, the shock absorber aspect (and I guess generally making sure the two sides are "balanced") had occurred to me, hence the question.
22nd Jun 2013 6:00pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6409 |
Doing both is usually recommended.
22nd Jun 2013 6:17pm |
Will do Joe, thanks - I found some American video on Youtube, looked pretty easy really, I wasn't sure whether it needed a plug in after to reset but the signs are not! |
22nd Jun 2013 6:31pm |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1702 |
And Dan @ Duckworths are the same price with free delivery Ash
22nd Jun 2013 6:33pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7812 |
Got mine from Dan back in January. Same price as island 4x4 if I remember right.
23rd Jun 2013 4:33am |
Reformed Member Since: 09 Oct 2010 Location: South Posts: 471 |
When I owned mine, I replaced only the blown side, to try and save money as it went straight after Christmas, but the following month, the other side did also go, so cost me twice in labour! (I chickened out doing it myself and got my then local indie to do it!) so would definately advise both, as has been said. Reformed |
23rd Jun 2013 6:11am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16294 |
As said above, would you change one spring or one shock absorber on a normal car? No... Then change the FF one's in pairs too... Simples |
23rd Jun 2013 9:26am |
Just another quick question - it may be on here in the search somewhere - but I've seen different views on which of the pipes on the crossover valve block you should slacken in order to release the pressure on the NEARSIDE bag? The offside is clearly not pressurised at all but the nearside may be. The car is sitting right down on it's knees, never seen it so low (I guess that's the self-levelling working against the burst bag) but I can't be sure there's nothing in the NSF bag. |
24th Jun 2013 12:55pm |
When they worked on mine, I noticed that the hose is "relatively" easy to reach on the strut. So I suggest to loosen that to bleed the air off. Or just punch a hole on the bag, since you are replacing the strut anyway.
24th Jun 2013 1:50pm |
OK, thanks, I'll have a look when I get it up in the air later on. Reluctant to punch a hole in this one when I could keep it as an emergency spare!!
24th Jun 2013 2:01pm |
If they can lift about 1.5tonne then they wont be light wee things
24th Jun 2013 2:25pm |
I work in the offshore industry, we tend not waste time too much considering the daily rate of the vessels we use. I guess that shows in day to day life as well
24th Jun 2013 2:27pm |
