Home > Maintenance & Mods (L322) > Air-con: blowing hotter after 20 mins |
dwillerton Member Since: 02 Oct 2007 Location: In front of you - and pulling away! Posts: 15 |
2007 TDV8 Vogue
21st Jun 2013 1:50pm |
MikeG Member Since: 14 Apr 2013 Location: Netherlands Posts: 182 |
I agree with Eugene... First have the gas checked, that will be cheapest and easiest to start with.
21st Jun 2013 3:01pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35217 |
i kinda think its not a regas job but something to do with temperature control or a sticky switch/flap? ... - .- -.
21st Jun 2013 3:15pm |
Baron Member Since: 20 Apr 2013 Location: Nr Drum Castle, Royal Deeside, Scotland Posts: 305 |
I agree with Stan. If you turn the temp right down and get cold air on a warm day it pretty much confirms you don't need a regas and the problem lies elsewhere. 4.4 TDV8 Vogue Baltic Blue MY11 |
21st Jun 2013 6:03pm |
Katash Member Since: 10 Apr 2011 Location: Hereford Posts: 700 |
Exactally the same issue I had few weeks ago, LHS cold RHS warm, regas solved it .... search my previous post for my theory on why there was a difference between sides.
22nd Jun 2013 4:23pm |
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 |
No experience behind this comment, so you've been warned. The aircon has an auto feature, so could it be 10 min of "must cool down car as quickly as possible" followed by warmer temperatures to "maintain current temperature"? Just an idea. |
22nd Jun 2013 11:38pm |
chris595959 Member Since: 09 Jan 2012 Location: Brighton Posts: 61 |
My 2010 SC has the reverse problem the faster you travel the colder it gets. You have to set temp at 22 and then gets to hot no in-between |
23rd Jun 2013 9:34am |
The air con in my '97 Discovery I works fine, but due to the heat from the V8, when the AC is off, the temperature range goes from HOT (at the cold setting) to UNBELIEVABLY HOT (at the hot setting). Not a problem in the winter; use the AC in the summer. |
23rd Jun 2013 3:46pm |
Anybody know how to get at the TEMP SENSOR to clean it? I have the A/C Head Unit out and cover off but still no access to behind TEMP SENSOR grille? |
8th Jul 2013 12:48pm |
