Home > Technical (L322) > Air Con Issues |
Liszt Member Since: 22 Apr 2010 Location: Northants, Uk Posts: 15 |
I had mine regassed a couple of weeks ago. It a slam panel label saying it had last been done in 2007. My chap said there was no refridgerant in the system but he refilled it with the UV dye in the refridgerant. Didn't work first time so he drained it and refilled it and got the car down to 5.8 degree C. Which is fine for me.
20th May 2010 2:41pm |
I had my P38 regassed by kwikfit, they sucked all the gas out but didnt put any back in, I only noticed because I looked on the print out. They even had the cheek to say the system was cooler than before. So get it done by a garage you trust before you start worrying unduly. Dan |
20th May 2010 4:00pm |
adara Member Since: 09 Dec 2008 Location: Eastern Europe Posts: 771 |
Does the electric fan work? |
20th May 2010 5:05pm |
IanV8 Member Since: 14 Jan 2010 Location: Dunfermline Posts: 502 |
I had mine re gassed and it worked for about a week then no cold air.
21st May 2010 11:16am |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6408 |
With the recent good weather have been driving the soft tops, but was in the FFRR a couple of days ago when it was hot and no air-con. So took advice (from here) to head down to Kwikfit.
7th Jun 2010 3:45pm |
RRVSE Member Since: 18 Apr 2009 Location: Bury Posts: 597 |
5kg out, 510kg in , that's one gigantic air-con system you've had installed!! Steve
7th Jun 2010 3:51pm |
That's what the Kwikfit man told me and I saw it on the readouts, whatever, it works now . Experience is the only genuine knowledge, but as time passes, I have forgotten more than I can remember Volvo V70 P2 2006 2.4 Petrol 170bhp Estate SE MG Midget Mk1 1962 Previous: L322 Range Rover TDV8 3.6 2008; L322 Range Rover TD6 3.0 2002; P38A Range Rover V8 1999 |
7th Jun 2010 4:49pm |
Can someone pleease tell me if the electric fan spins when compressor engages? Mine has been replaced and still doesn't turn... |
7th Jun 2010 5:42pm |
dantheman Member Since: 02 Feb 2009 Location: North: Lancs Posts: 477 |
Which electric fan? I've not looked specifically at the FFRR yet (as my aircon would still freeze the balls off a brass monkey).
7th Jun 2010 7:53pm |
I'll have to take a closer look at the LM's electrics, but generally there are 2 switches on the high pressure lines of an AC (well 3 actually): low/high for the compressor and a somewhat-less-than-high-high switch for the fan (condenser fan all the way in front). Generally, the low / high is somewhere in the vicinity of 2 bar / 30 bar (the compressor will only switch on in between) and 18-25 bar for the electric fan.
7th Jun 2010 8:48pm |
GKP Member Since: 01 Aug 2009 Location: Hants Posts: 75 |
There's no way you've had over half a tonne of gas added to your system. Not sure you should be reading this bit. |
8th Jun 2010 1:03pm |
It's just I have never seen that electric fan spinning, ever! The viscous one does a lot when it's hot but never the electric (the one in front of the radiator) one... |
8th Jun 2010 2:43pm |
So what did the readout mean? . Experience is the only genuine knowledge, but as time passes, I have forgotten more than I can remember Volvo V70 P2 2006 2.4 Petrol 170bhp Estate SE MG Midget Mk1 1962 Previous: L322 Range Rover TDV8 3.6 2008; L322 Range Rover TD6 3.0 2002; P38A Range Rover V8 1999 |
9th Jun 2010 5:05pm |
