![]() | Home > Maintenance & Mods (L322) > Hard brake pedal issue |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 ![]() ![]() |
When you wound the pistons in did you check the brake fluid level? A friend of mine forgot and it pushed the level so far up it was leaking out of the reservoir ! Previously..
rjp996 Member Since: 28 Apr 2009 Location: East Sussex Posts: 22 ![]() ![]() ![]() |
Yep, have to say I've done that too in the past..... But this time no, fluid levels all good. May have to go over the the in laws an try out his Range Rover brakes to see if they do the same thing (could do with a weekend if not fixing cars). |
Katash Member Since: 10 Apr 2011 Location: Hereford Posts: 700 ![]() ![]() ![]() |
Pretty sure my old Freelander did the same, if I pumped the brakes while stationary they got progressively harder and harder until the pedal wouldn't move - never noticed if this affected braking or not tho. |
Baron Member Since: 20 Apr 2013 Location: Nr Drum Castle, Royal Deeside, Scotland Posts: 305 ![]() ![]() ![]() |
I get the same on my 11MY TDV8. I thought there was something wrong (and maybe there is!) but it goes away once the engine has started and the car is moving again. With the car stationary and engine stopped, pumping the brake pedal 3 or 4 times the movement reduces to a solid pedal. Start the engine, no change, start to move the car and the pedal softenes and returns to normal operation. Until it does the brakes hardly work so I guess it must be something connected with the servo, as suggested earlier 4.4 TDV8 Vogue Baltic Blue MY11 |
Ahh yes I remember now - mine was (almost) the same as Baron - Pumping the brakes with the engine off made them progressively less and less travel until it wouldn't move - then starting the engine with foot on brake pedal within 1 second of engine going the pedal returned to normal. |
barracuda816 Member Since: 11 Jun 2012 Location: oxfordshire Posts: 213 ![]() ![]() ![]() |
Don't worry guys. This is completely normal.
Yep - all sorted and thanks for the replies. I checked out the servo by pumping the brake until vacumme exhausted, then left foot on pedal and after a few seconds the pedal goes down again as pressure builds up - so all good, just something I have never noticed before. |
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 ![]() ![]() ![]() |
In fact, this is an easy test for power brakes when looking at a new (used) car that my Dad taught me.
