Home > In Car Electronics (L322) > dash lights HELP
W88DY M
United Kingdom 2003 Range Rover Vogue Td6 Oslo Blue
dash lights HELP
Hello all, just a quick one has anyone came across this combo of lights if so any clue what they are
Any help would be much apreashaited
Mark :thumbsup:
Post #194645 17th Jun 2013 7:35am
I take it you have tried turning the steering wheel all the way to the left then all the way to the right? Previously..
Post #194646 17th Jun 2013 7:39am
how did these lights appear?
have you had a flat battery? ... - .- -.
Post #194647 17th Jun 2013 7:41am
Other question is how old is your battery as that would be the next most likely cause... FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #194649 17th Jun 2013 7:41am
W88DY M
Yes done the full lock to full lock, battery is only 6 months old
It happened 2 days ago just driving down the road
Post #194651 17th Jun 2013 7:48am
could be,
alternator
battery
abs sensor.
if you search "hdc inactive" there is loads of info on this.. ... - .- -.
Post #194652 17th Jun 2013 7:57am
W88DY M
Thanks stan ill have a look. I'm going to book it in today to see what's what
Ill let you's know when I find out
Thanks again mark Thumbs Up
Post #194653 17th Jun 2013 8:03am
ebajema
First check is making sure charging voltage and current are within the "normal" range and the battery is actually still OK. Even new batteries can fail from time to time. MY 2010 5.0 SC Galway green and sand interior!!
Post #194655 17th Jun 2013 8:08am
W88DY M
Can low voltage make these lights come on?
Post #194656 17th Jun 2013 8:13am
The two lights on the right are brake related, one is the Emergency Brake assist and the other is an ABS one, which as you know normally extinguishes after ignition.
The one in the centre is for the DSC.
I would guess these have all be caused by an electrical issue, such as low voltage or poor charging voltage. Discovery 4 HSE
Post #194664 17th Jun 2013 9:10am
W88DY M
If It is my battery and I charge it will this clear the lights?
Mark
Post #194665 17th Jun 2013 9:14am
Check voltage while running
Then check after about 30minutes of engine off.
Are you doing a lot of short runs?? FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #194666 17th Jun 2013 9:15am
W88DY M
Yes it only goes on short trips. This might sound stupid but how do I check the voltage
Mark
Post #194668 17th Jun 2013 9:19am
On slightly newer cars with the touch screen sat nav you can get into a secret diagnostic menu via the screen and see real time figures, I can't recall if or how it is done on the older cars though. (Known as the 753 hack)
Anyone here remember? I seem to recall a 4 digit code? Discovery 4 HSE
Post #194672 17th Jun 2013 9:47am
there's this for the 2002-2005 navs,
http://www.bimmernav.com/Advanced_Programm...splay.html
or
http://www.fullfatrr.com/wiki/Secret_Codes ... - .- -.
Post #194678 17th Jun 2013 10:01am
