![]() | Home > Technical (L322) > Mystery wheel balance problem |
case Member Since: 05 Aug 2008 Location: Wiltshire Posts: 5 ![]() ![]() ![]() |
I had 4 new tyres fitted to my Vogue SE TDV8, obviously as part of the fitting the wheels were balanced.
andyw Member Since: 15 Oct 2009 Location: united kingdom Posts: 160 ![]() ![]() ![]() |
the sensors are attached to the valve if they are moving during the journey they they may put the ballence out it
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6373 ![]() ![]() ![]() |
Does it only happen when the tyres are cold?
TPMS is the bane of my life. Discovery 4 HSE
There is a valve in the steering rack that sometimes goes bad, it is dependent on how fast you accellerate so can seem to be completely random as to when you get the bad vibrations:
