![]() | Home > Maintenance & Mods (L322) > air supension BIG FAIL |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 ![]() ![]() |
I know that on my car the compressor would not start until I had done the steering recalibration.... Turn all the way left then all the way right. Previously..
djharm Member Since: 28 Dec 2012 Location: breda Posts: 78 ![]() ![]() ![]() |
yeah, I know. did that. Called the stealership and it might have to do something with a fault code from the trasfer box. Don''t know why but that is what they said. indy is gonna look into it tonight, otherwise it's off to the Stealership tomorrow... cars on the side;
Seems to be a broken comp rxt000013 cars on the side;
wslr Member Since: 04 Dec 2011 Location: Wellington, Somerset Posts: 64 ![]() ![]() ![]() |
I had a guy come in two weeks ago. A local garage had used a lesser diagnostic system in trying to calibrate the RLM. This caused the front LH airspring to explode. We connected with T4 and did the calibration routine several times to get it right.
RS2000CUSTOM Member Since: 25 Apr 2013 Location: The Black Country Posts: 137 ![]() ![]() ![]() |
Read my thread - http://www.fullfatrr.com/forum/topic18252.html |
20" rims. My left front also exploded. Replaced both front springs and after that they tried 3 differend computers on it but nothing worked. now its at the dealer who can also not log into the EAS ECU. so they say it needs to be replaced. Personally I don't think that is the cause but we will see tomorrow. cars on the side;
@rs2000custom Read your post, with one of the computers they used the did get the backside back down. So I dont know if that is the same issue but will keep it in mind. cars on the side;
The 20" should calibrate fine with T4. It tends to be a problem because T4 will only calibrate on the standard sizes.
they have some red unit, witch connects with a wireless device. cars on the side;
it look a lot like this one, but im not 100% sure if it is the same
Probably a Snap-On Modus or something. You'd be better taking it to a dealership to do properly with T4. I've only experience with the Utrecht dealership, but they were pretty good at this sort of thing. |
It is at the dealership right now. that was the comp ( or something alike) my indy was using. cars on the side;
Dealer can also not access my EAS ECU. so it will be replaced 2morrow cars on the side;
Um, rim size shouldn't make any difference as long as the correct sized tyres are fitted, distance between hub centre and ground should be the same. Will of course depend on what measurements you take when calibrating |
