Home > eBay & Bargain Spots > T91 park heat remote fob |
dave699 Member Since: 03 Apr 2012 Location: Redcar Posts: 457 |
GraemeC - me too, I had a brand new one supplied with the car as it was missing and i pointed it out to the dealer. But at £16 I was compelled to buy another - for a rainy day!
7th Jun 2013 4:50pm |
Baron Member Since: 20 Apr 2013 Location: Nr Drum Castle, Royal Deeside, Scotland Posts: 305 |
Ditto
7th Jun 2013 8:45pm |
Nomad Member Since: 26 Oct 2011 Location: Ringwood, Hants Posts: 300 |
Job Done!
8th Jun 2013 2:00pm |
As you can see from the posts above, taking out the fuse rarely works. You have to take off the whole fuse box and retaining bar in the rear compartment. Once you've done that you can get access to the receiver at the back. Unplug the multi plug for a couple of minutes. Plug it back in then press the off button on the remote for a couple of seconds... this assumes 2010+ is the same. 2012 5.0L S/C
8th Jun 2013 3:18pm |
jonlewis Member Since: 06 Nov 2012 Location: UK Posts: 308 |
On my 2008MY TDV8 it was Fuse 16 in the rear fuse board.... worked like a charm.... with the added bonus of being much easier to get to !! 2011 Stornaway Grey 5.0SC Autobiography |
8th Jun 2013 3:41pm |
jez000 Member Since: 17 Apr 2009 Location: Yorkshire Posts: 742 |
Thanks Nomad, ill take a look to see if I can find the T91 receiver behind the rear fuse box then. 2021 P400 Silicon Silver AB
8th Jun 2013 3:42pm |
Let me know what you find coz I can't work out how to do it on my 11MY. There's a black box with T91 on a label attached to what looks like a fibre optic cable connected to it. That box isn't behind anything, it's to the right of the rear fuse box.
8th Jun 2013 8:58pm |
Wow that was easy, removed the cover on the right hand side of the boot, pulled the power out of the T91, left for 5 secs, plugged power back in then held the off button for a couple of secs on the remote as described earlier and that's it, takes less than a minute. 2021 P400 Silicon Silver AB
9th Jun 2013 1:47pm |
So, just to be clear, the Telstar T91 black box to the right of your fuse box in the boot of the car. You unplugged the black 3 wire connector, left for over 5 secs, plugged it back in and pressed the off button on your heater remote less than 5 secs later and all was well? Did you do this with the ignition on or off? I've tried it with the ignition off and I still can't start my heater. Whenever I press either button the remote LED flashes rapidly between red and it looks like yellow. No constant red or green illumination. 4.4 TDV8 Vogue Baltic Blue MY11 |
9th Jun 2013 4:58pm |
I think yellow means the remote battery is on the way out. 2012 5.0L S/C
9th Jun 2013 5:12pm |
Hi Baron, I did it with the ignition off but within a minute of unlocking the car, Then as you described I pulled the 3 wire connector from the T91 Telestart box left it 5secs then plugged it back in then within 5 secs pressed down the off button for about 3 secs. The unpaired remote will flash more rapidly but when it's paired it will go solid. As nomad mentioned if the light goes orange the battery is on the way out. 2021 P400 Silicon Silver AB
9th Jun 2013 5:36pm |
Thanks jez, looks like my poor remote battery is preventing me from pairing. I'll get a new one tomorrow and start again. Thanks for clearing up the pairing procedure for a MY11 car. The location of the electronic gubbins seems to have been moving around the boot of the car almost with each successive year! 4.4 TDV8 Vogue Baltic Blue MY11 |
9th Jun 2013 6:21pm |
My 1st one arrived this morning
10th Jun 2013 1:06pm |
Collected mine from sorting office this morning.
10th Jun 2013 1:50pm |
