Home > Technical (L322) > Bonnet release stuck on one side |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16281 |
Are you sure its not releasing and not just stuck in the hole? 1st did they remove or re/align your bonnet? We have had a load of instances where bonnets will not open after being adjusted (or removed and refitted)
9th Jun 2013 8:32am |
MikeG Member Since: 14 Apr 2013 Location: Netherlands Posts: 182 |
Thx Craig for the reply and suggestion... Will give it a try as you described to see if it opens.
9th Jun 2013 8:50am |
9th Jun 2013 8:51am |
By the way Craig, there are some rumors within the company I work for that I may be re-locating to the UK... If that's indeed the case I will look you up for a nice FF. Looking at the price differences for cars in the UK and the Netherlands I will probably be looking for a TDV8... now just keeping my fingers crossed that the rumors are based on something and not just someone not having all the correct information or understanding it wrongly. Mike.
9th Jun 2013 9:00am |
No Problem sir |
9th Jun 2013 9:17am |
My suggestion, let Gary get you a nice car and Craig make it beautiful
9th Jun 2013 10:35am |
Eugene, keeping the fingers crossed but it would definitely be great to pay less for a more recent model car... The freeking taxes they charge on cars over here is bloody robbery!! But nothing sure yet so have to wait to know more before we get to excited...
9th Jun 2013 1:12pm |
After checking out Wiki found the procedure to re-synch the mirros... The double tapping didn't do the trick so just kept tapping till I upset the ECU enough to reset the mirrors... at least now they are in synch again Mike.
9th Jun 2013 1:29pm |
Quick update on the original topic... Today went to my Indy trying to get the bonnet released again. Turns out the release pin of the lock on the passengerside (LHD) has some small plastic part which has broken off. So the release cable still works but due to the plastic part it doesn't release the lock. They could force the lock but then no way to keep it closed again till a new lock has been installed and since I want to keep driving the FF we decided to order the new lock first and then finalize the repair next week.
20th Jun 2013 6:55pm |
