Home > Technical (L322) > Cig lighter - Permanently on? |
Googsy Member Since: 02 Jun 2011 Location: Where men are men and sheep are nervous. Posts: 2947 |
What wattage solar panel charger is best . If I have tints will it still work if connected to rear window ? Present :2008 TDV8 HSE
4th Jun 2013 11:05pm |
Dont think they will work very well if at all with tints googs
5th Jun 2013 8:52am |
netsonic Steve Member Since: 06 Oct 2010 Location: Sussex Posts: 165 |
Solar panels do work through tints but with a slightly reduced voltage relative to the light, with the sun shining i lost about 2 volts when behind the tint to not..........
5th Jun 2013 10:57am |
Thanks for comprehensive answer. I have factory tints so might be a bit better than normal. Its only from reading this post that I now plug out my phone charger as I was constantly getting bong on start up "Special Programs off" and believed that to be a contributory factor.Also my Bosch is apparently only charging to 70 percent of capacity as noted at last service its 2 years old. Present :2008 TDV8 HSE
5th Jun 2013 11:23am |
