Home > Technical (L322) > Cig lighter - Permanently on? |
SKOT Member Since: 24 Oct 2012 Location: Milton Keynes Posts: 792 |
Hi All,,
18th May 2013 11:54am |
Nomad Member Since: 26 Oct 2011 Location: Ringwood, Hants Posts: 300 |
That's what I do. I had the dealer make the front cig socket live when I bought the car. I am often abroad for weeks at a time and sometimes the wife gets back before me. I just plug in my ctek charger, lay the cable under the door and lock it up. When we get back just unlock, unplug and away we go. Just don't let anything drop in the socket or leave anything else plugged in as its permanently live. 2012 5.0L S/C
18th May 2013 12:09pm |
The power point in the boot is permanently live, so no need to change the front one anyway.
18th May 2013 12:13pm |
Mine has a new OEM battery, alternator and final stage resistor and after 2.5 weeks too low (9.2V) to start the vehicle. Admittedly I have been to it a few times to get stuff out the boot etc. but I'm very glad I'm not in an airport car park!!!
18th May 2013 12:51pm |
DTaylor Member Since: 15 May 2013 Location: Manchester Posts: 163 |
my cig lighters aren't working at all, any one know a fix for that |
18th May 2013 6:23pm |
DTaylor, the fuse(s) is/are likely blown. MY 2010 5.0 SC Galway green and sand interior!!
18th May 2013 7:23pm |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 |
This is the set up I used... Maplin as well. Plugged into the socket in the boot.
18th May 2013 7:48pm |
Budgie Member Since: 09 Jul 2012 Location: Stornoway Posts: 267 |
I've got a smaller Maplin's solar panel than Contraband that's stuck to the inside of the rear side window using double sided numberplate tape and plugged into the boot socket.
18th May 2013 8:28pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7964 |
That's a seriously big panel - do you really need one that big or did you have it lying around from another project ? |
18th May 2013 9:44pm |
Lol... Yes, for another project.. But it did the trick in keeping my battery topped up until it died.
18th May 2013 10:13pm |
That panel is seriously big!!! I could power my whole house from that! 2006 4.2 SC
19th May 2013 9:11am |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6410 |
Even if it has a one way diode ? . Experience is the only genuine knowledge, but as time passes, I have forgotten more than I can remember Volvo V70 P2 2006 2.4 Petrol 170bhp Estate SE MG Midget Mk1 1962 Previous: L322 Range Rover TDV8 3.6 2008; L322 Range Rover TD6 3.0 2002; P38A Range Rover V8 1999 |
19th May 2013 10:19am |
That would make sense about the diode, but it was in the user manual to make sure it was unplugged before starting the car. Previously..
19th May 2013 12:52pm |
