Home > General > Considering buying a Rangie 4.4 V8 |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35379 |
woodpecker or doorbell dont work.. ... - .- -.
4th Jun 2013 11:04am |
seriously though, i would check the oil level and ask if the correct type has been put in, and get a screwdriver and try and localise the sound.. ... - .- -.
4th Jun 2013 11:09am |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 |
The big ones you can fax about on here and bmw forums are vanos systems failing and timing chain guides failing. They area About the worst. Think a garage would charge round the £1800+ for doing the vanos and £1000+ for the guides. Someone on here did the guides themselves and it was a of a job. Their wrist case scenarios. an ex member had a similar issue and he replace the oil filter housing @ circa £70 and it fixed the isssue. the NRV in the housing had failed allowing the oil to drain from the top of the engine. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
4th Jun 2013 6:56pm |
