The big ones you can fax about on here and bmw forums are vanos systems failing and timing chain guides failing. They area About the worst. Think a garage would charge round the £1800+ for doing the vanos and £1000+ for the guides. Someone on here did the guides themselves and it was a of a job. Their wrist case scenarios. an ex member had a similar issue and he replace the oil filter housing @ circa £70 and it fixed the isssue. the NRV in the housing had failed allowing the oil to drain from the top of the engine. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
