Home > Technical (L322) > possible fuel pump issue? |
ALL L322 have an intank pump that has a mechanical mechanism that balances between the two halves of the tank. This motor or mechanism can fail and then when the level is to low the other pumps in the system just draw air up.
28th May 2013 10:36am |
PS the right saddle will fill up to about 70% full and then start to spill over to the left saddle before then filling the rest of the tank so the 5 litres would have given some juice to get it going again.
28th May 2013 10:38am |
Bushy513 Member Since: 25 Feb 2013 Location: Colchester Posts: 392 |
Same problem as me, in tank balancing pump. All I'll say is that the main dealers in my experience have been less than helpful, good luck. It's a bit of a pain to get to the inspection panels in the back to see. But once the rear seats are fully forward, with the carpet up. You'll see the two round inspection panels open them up, and as others have said you'll see fuel just in one side. Funny enough mine last went with 55 left in it. Bushy
28th May 2013 11:51pm |
goldsax Member Since: 16 Jul 2012 Location: leicestershire Posts: 196 |
thanks for the info.
29th May 2013 8:19am |
Not in my experience no. It's part of the problem because most mechanics these days seem to be diagnostic fault finders only. So when no codes are present their stumped! Bushy
29th May 2013 8:34am |
