Home > Technical (L322) > Leak from Around Oil Filter
TtheArab
2003 Range Rover HSE 4.4 V8 Giverny Green
Woke up this morning to find small pool of oil below NSF. Opening engine bay shows some spray from oil filter with engine block and head itself dry.
Anyone else had this before ? Car has just had first decent run (200 miles) since I got it and is in need of service I suspect. Could oil filter be blocked and by pass is causing pressure levels high ?
Post #190646 26th May 2013 11:20am
daveo
quite common for the o ring to leak on the 4.4, if it has been re-used or over tightened, new filter and it will come with a o ring, V8 facelift Range Rover Autobiography 22" wheels.
Post #190730 26th May 2013 10:08pm
TtheArab
Thanks Dave. Will get new filter when I get back.
Post #190764 27th May 2013 8:18am
TtheArab
New filter fitted today and engine bay cleaned. Will see what it's like after a run. FWIW the old filter disintegrated when we took it out.
Why do people get these lovely cars and fail to look after them ?
Post #191069 28th May 2013 8:39pm
verydisco
Hi
did it solve it in the end? thanks in advance Wink l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #334385 25th Jun 2015 1:34pm
