Home > Technical (L322) > Replacement Key
nbunney
Replacement Key
Anyone recommend, apart from a stealer, to get a complete key from?
Early non flip type.
And I assume it will need programming.
Cheers
Post #19020 28th May 2010 6:21pm
GKP
United Kingdom 2003 Range Rover Vogue 4.4 V8 Cairns Blue
I think you're going to have to bite the bullet on this one. Talk nicely to your wallet to prepare it for the shock... Not sure you should be reading this bit.
Post #19032 29th May 2010 9:14am
hoppy_70
England 2018 Range Rover Autobiography 2.0 PHEV Loire Blue
Not sure with Range rover but I know BMW keys can be coded by pro locksmiths. Worth ringing someone like autolocksmith or other local locksmiths to see whether they can supply and code.
Post #19034 29th May 2010 9:41am
stevegt
United Kingdom 2006 Range Rover Autobiography 4.4 V8 Cairns Blue
I am lead to believe that Timpson can code Land Rover keys, Take you old one in with you and they can copy the code accross. The Land Rover and BMW key is essentially identical except for the logo on the buttons. The other thing you could try of course is to just take the electronic gubbins out of you old key and pop it into you new replacement one. No messing around with recoding keys... and only the cutting to get done. 06MY 4.4 V8 Autobiography Cairns Blue with Navy & Parchment Interior
Post #19074 29th May 2010 3:46pm
nbunney
Thanks for the advise guys.
No good in swapping the insides, as I only have 1 key and want a spare.
Post #19076 29th May 2010 4:21pm
Andy
No they can't. Been there, tried that!
The keys are around £180 from the dealer. I bought one off ebay brand new, but it was bought from the USA and was a different frequency and didn't work. The only option is the dealer I'm afraid. It will come pre-programmed to your car, I'm told. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #19204 1st Jun 2010 2:07pm
