Home > Maintenance & Mods (L322) > Spraying should be done this week |
Rich86 Member Since: 10 Mar 2013 Location: Surrey Posts: 509 |
One question...did you have the bonnet sprayed in situ or did they remove it?
20th May 2013 6:10am |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3779 |
I don't know, they said they would, I removed and refitted the letters and all the other bits with the exception of the bonnet grill which they did. Sorry I can't be more help. Geoff |
20th May 2013 7:03am |
Phil H Member Since: 17 Oct 2010 Location: Monmouthshire Posts: 34 |
Did you have to do any prep work on the lettering? Mine are looking a bit sad (Brunel) and I know that the paint can be made up. Another question, spray or brush? |
20th May 2013 9:02am |
Could be worth investing in a new set of letter from Dan @ Duckworths. The latest TITAN lettering really freshens things up. |
20th May 2013 9:04am |
I'm trying to keep the car original as possible. |
20th May 2013 9:16am |
New Brunel then |
20th May 2013 9:30am |
Letters were actually very easy, got them off with a sharpened scraper and although the bonnet was being sprayed I was careful not to do any damage, masking tape and/or cloth when sliding said scraper under the letters. Then I got the tape residue off, and put my own on, then light rub down, sprayed with Simoniz 5 wheel silver, lots of light coats finished of with some acrylic lacquer -again lots of thin coats. You need to make a template before removing letters so you can stick them back on in right place - they sit on an arc, not straight.
20th May 2013 11:07am |
So, final piece close to dropping in place, just ordered some new mirror caps (Oslo Blue) from Dan (yes he still has a few sets left) will get them sprayed and fitted when tailgate is done. I reckon I will break the chrome ones getting them off, particularly as one already has a crack in it
22nd May 2013 2:56pm |
Caleb119 Member Since: 20 May 2013 Location: Canada Posts: 6 |
24th May 2013 7:14am |
