Home > In Car Electronics (L322) > Are these the plugs that i connect a Bluetooth ULF to? |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7796 |
Hi,
18th May 2013 6:57am |
Sorry, it's a 54 pin black plug isn't it - not had a coffee yet 2011 Range Rover Vogue SE 4.4 TDV8
18th May 2013 7:04am |
Tuts Member Since: 24 May 2012 Location: Bishop’s Stortford, Herts Posts: 201 |
I've read your post, I've had a really good look but can't seem to find the back plug, someone on an older post said that if the white plug is open and free then I'm missing the loom/harness required
18th May 2013 8:12am |
It initially appears like your car may not be prewired, though to be fair, the microphone harness wiring seems to be the hardest bit to do if thats the case, and you have that already, so you may just be missing the extra loom from the boot area - along with the bluetooth antenna lead, as you suggest.
18th May 2013 9:05am |
Thinking aloud - Where does the other end of the microphone connection go then ?
18th May 2013 9:07am |
Thanks mate, you've been v.helpful, will speak to Baris as I'm gonna get him to update my BM54. 2003 Vogue 4.4 V8 Java Black |
18th May 2013 10:31am |
Deasy Member Since: 26 Oct 2011 Location: Warwickshire Posts: 210 |
http://www.fullfatrr.com/forum/topic9811-15.html
18th May 2013 2:46pm |
Oh and that link I posted shows how much you can pick them up for.
18th May 2013 2:47pm |
There is one from an X5 here for £60.
18th May 2013 3:09pm |
Sorry one more Question ! On your car was the 54 pin plug attached further down in some way to the white plug? Or was your white plug open/unused as mine is? 2003 Vogue 4.4 V8 Java Black |
18th May 2013 5:17pm |
I can't see an unused white plug in the back of my car. Can't follow the cable properly as I've re-routed it and tie wrapped it out the way.
18th May 2013 7:10pm |
ccfj1 Member Since: 14 Feb 2013 Location: UK Posts: 32 |
22nd May 2013 8:57am |
CCFJ1 - thanks for offering to make a loom for me - i have had another look in the boot to see if i can locate a mic pick up to see if I need the extra Mic loom too- and to be honest i'm struggling to find what looks like a mic plug.
24th May 2013 11:13am |
No problem.
OK, good so far.
OK.
Hmmm, I'm by no means an expert on the RR mate, do the wires (at least 3 of them) match up with the mic wires in the roof?? Also does the car have a pair button located anywhere on the dash/console? (not the MFSW). If this plug has 5 wires, then it is possible that this could be the pair and mic loom/pins. if it is then this would make sense and be possible to use.
OK, good.
Hmmm.
Not sure, I would expect that the mic would have 3 or 2 wires at least. The Mic lead must go somewhere and the logical place would be the boot so it would be near the phone module, its the only thing that makes any sort of sense. Does the 5pin plug have any of the same colour wires as the mic plug (in the roof), can you do a continuity test if it does. |
24th May 2013 11:28am |
