Home > Technical (L322) > Coolant leak |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 |
yes 2 pips/blobs on the float. The max level the second blob(lowest) shouod be level with the rim of the expansion tank. min level the top is flush with the rim. If your puddle is front drivers side then it's prob the rad leaking if it's never been changed. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
21st May 2013 10:15am |
Rich86 Member Since: 10 Mar 2013 Location: Surrey Posts: 509 |
Hi Rob,
21st May 2013 5:40pm |
if its the rad there's no need to remove the bumper. The rad slides of from the top once the viscus can is removed. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
21st May 2013 6:11pm |
Rob,
21st May 2013 8:02pm |
if you undo the fan cowling you can normally get enough of a view at the rad to see if there any staining from the coolant. Shouldn't take long to do this. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
22nd May 2013 12:09am |
Ok thanks, hopefully the garage can have a look tomorrow.
22nd May 2013 6:45am |
Lets hope is is just a leaky hose or hose connection that is not on tight, like RRG had a while ago after his radiator was replaced.
22nd May 2013 7:24am |
Lets hope so. I just had a chat with my car and said that all this work needs to stop.
22nd May 2013 7:32am |
I'm glad mine is a NAS model, they seem less "sensitive" to a good I actually think they secretly like the f-word. MY 2010 5.0 SC Galway green and sand interior!!
22nd May 2013 7:39am |
jim2RRs Member Since: 07 Feb 2012 Location: Genesee, Colorado Posts: 147 |
Both of mine are NAS; and neither seem to mind the occasional f-bomb lobbed in their direction.
31st May 2013 10:03pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6409 |
And just in case no-one knows what JimRRs is going on about:
1st Jun 2013 8:57am |
