Home > My Range Rover > Supaguard
dan_uk_1984
If they've removed the swirls they have cut and polished the paint.
As RRUK has already said, it sounds like they've removed the paint from the badges. Very easily done if you were to pass a power polisher over them!
Get them to supply and fit new badges FOC.
Dan
Post #18920 27th May 2010 2:53pm
elbitrevnoc
United Kingdom 2006 Range Rover Vogue SE Td6 Buckingham Blue
I fear you may both be right. I haven't had a chance to take a really good look at this yet, but the thought did occur!
I'll take a good look tonight and try to put a picture up. If it IS damage to the painted surfaces then I will be going back to them for a new grill and bonnet lettering. The best advice seems to be not to let a dealer near your car any more than is absolutely necessary! Mad
Post #18927 27th May 2010 4:00pm
elbitrevnoc
I've posted an image of the damage in my gallery and would appreciate any views if you have time to take a look. It certainly appears to be some sort of mark/staining of the paint surface, but it could be that it's something that has actually attacked and eroded the paint and therefore it won't be something that can be simply cleaned off.
Post #18958 28th May 2010 9:05am
Have you tried WD40 on it surprising what that stuff can clean ...... to me it looks like stain runs from your bonnet ====================================
Post #18965 28th May 2010 9:28am
elbitrevnoc
'Fraid not Mick. WD40 was my first weapon of choice!
Post #18970 28th May 2010 10:15am
delamo
England 2007 Range Rover Vogue SE TDV8 Tonga Green
Seen the photo of the damage - Shocked WHAT THE F Censored k!!! Exclamation
Demand your local dealership replace the grill immediatly (+ any other damage you believe they are responsible for) - Twisted Evil cause a scene in the showroom if needs be...
I would be going fCensoredg ape s Censored t if it was my car they had done that to and they were trying to fob me off.
Whilst I appreciate you may be more mild mannered than me elbitrevnoc - this will get you nowhere when dealing with the muppets responsible for doing this.
I know it is only a grill but it is your grill and they have damaged it - you won't be able to polish that out or improve it without replacing it for a new one - this should have been offered straight away as it has spoiled the look of your car. Why should you spend your time/effort/money correcting their damage.
You have spent thousands of your 'hard earned' on your pride and joy and for them to not fix this immediatly to your satisfaction is disgusting.
Just because your LR Dealer Principal might wear a snappy suit and tie does not make him any better than you.
I had a real face to face arguement with my local dealers DP (in the showroom) shortly after they delivered my latest RR - but what his team of staff did at the time was unforgivable and I made damn sure he knew it.
NOW he has provided me with his own personal/direct telephone numbers 'should I ever have any problem etc.' and I am offered the use of his car each time/every time- when in for servicing or repairs - not the usual demo's.
Whilst, deep down, he probably hates me (not that I give a toss) I have had nothing but the best attention from that dealership since.
Post #18989 28th May 2010 1:57pm
elbitrevnoc
Believe you me. I'm not taking this in my stride and they ARE going to sort this!
Already talking to the dealer principal - not yet convinced that he's doing much for me either, but haven't reached my deadline yet!!!
And, as it goes, I can wear a pretty snappy suit too!!
Post #18995 28th May 2010 2:44pm
delamo
Good for you Thumbs Up NEW GRILL (fitted) nothing less!
Post #18997 28th May 2010 2:58pm
v8 andy
i remember going with a friend of mine to pick a brand new audi quattro up,26k in a plastic carrier bag,we walked into the showroom & the salesman said to him that another salesman had taken some out for a test drive in his new car has they were interested in buying a quattro.
my friend turned to the salesman & said you better get me another car then & walked out of the showroom still with his money.
V8. always here to entertain,,,,lol.
Post #19002 28th May 2010 3:50pm
mzplcg
FWIW, that will come off. It looks like staining form a dirty mop head with a combination of G3 and dirty water.
You would be amazed at how shoddy the bodyshops actually are over this kind of thing and it's all too common to see a bucket of dirty water, a large tin of G3 and a really manky mop head. All of this adds up to a lousy job almost every time. Bear in mind also WHY bodyshops use G3 ..... Wink Cheapness, that's why. A 5 litre tin costs less than 1 litre of top quality polish like Menzerna and the way these muppets throw it all over the car that soon adds up. G3 is (after T-Cut) the nastiest junk I've ever tried, and being a hobby detailer I've tried at least a dozen different polishes.
To be fair, these blokes are on a set time/price for each job so it's the system which is at fault, not necessarily the moron at the end of the mop, although the usual lack of active brain cells never helps either.
So, if you would rather do it yourself I would suggest a small bottle of Menzerna PO85RE, a microfibre cloth and plenty of elbow grease. Not easy I accept but the result is guaranteed whereas the result from another visit to the stealer will be more damage and thinner paint.
If you're interested I can post you out a sample sized bottle of the 85RE which will be plenty enough for what you need. Would be next week now - not going home before monday but you are welcome to this FOC.
Hope this helps a bit.
Dom
Post #19005 28th May 2010 3:58pm
elbitrevnoc
Dom, you have PM.
Thanks very much!
Phil
Post #19042 29th May 2010 10:06am
elbitrevnoc
A quick update. Firstly let me say that Dom is a scholar and a gent, who went out of his way to send me a sample bottle of Menzerna PO85RE and it's very much appreciated. Star man!
Sadly, either through user error or the damage being worse that I thought, I wasn't able to remove the marks. This despite my best efforts - plenty of time, lots of elbow grease, but no appreciable improvement. However, I'm relatively relaxed about it as I had already spoken with the Dealer Principal who has assured me that he would replace the damaged parts if I was unable to clean it up - we're sorting something out next week.
I'm slightly nervous about what else they might do to it, but I think the problem is now high enough on the DP's radar for him to make sure that nothing else goes wrong now! I'll update when sorted.
Thanks again Dom.
Post #19895 11th Jun 2010 7:49pm
jayzee
2006 Range Rover Vogue SE Supercharged Java Black
Crikey! Sounds like the muppets RRUK had the pleasure of dealing with. Shocked
Honestly mate, they'll sort it for you, and this will all be but a distant memory soon Thumbs Up
People fook up, some blatantly fook up, but either way they have a responsibility to put that right for you.
Nowt worth having a coronary over - especially a car Laughing Java with Ivory 2006 4.2 Supercharged. 23.5k miles - NOW SOLD!
Post #19897 11th Jun 2010 8:44pm
elbitrevnoc
I just thought I'd let you all know the final conclusion of this sorry tale of incompetence. Car has now had both the grill and bonnet badges replaced with new - it seemed that the damage was etched into them and it couldn't be cleaned off.
That's the good news and the further good news is that I also got them to remove and re-spray all the door handle scuff plates. I had complained that there seemed to be some evidence of peeling paint around the edges of each of these and I suspect that it might have originally been disguised a bit with filler polish or similar. As a bonus they also replaced the telephone unit, as I couldn't transfer my phonebook via Bluetooth - it turns out that the software for this should have already been present, but it was the unit itself that was faulty.
Finally, the BAD News (there had to be some). the car was returned to me with only the most cursory of washes (if any) and the interior certainly hadn't been cleaned at all. Every one of the door cards, the central storage box and the rear luggage cover was smothered in oily finger prints (sound familiar RRUK???). I have let my feelings be known, but I've cleaned it up myself this morning - there's no way I want them going anywhere near it again. For everything they fix, there seems to be at least one thing they cock up! That's main dealer care for you!
Oh well - 4 months in and I finally have a car that I'm happy with!!!
Post #22577 17th Jul 2010 11:01am
