Home > General (L405) > Getting an SDV8 4.4 Vogue SE
Yes, that's right, you read it correctly.
I am getting one, May 15th.
HAHA fooled you, just a day long test drive while mine is in!. Still, can't wait, finally getting my hands on one, and a damned high spec one. Must keep my head..... Big Cry Discovery 4 HSE
Post #186170 2nd May 2013 12:09pm
Thumbs Up Enjoy... It will be interesting to hear your thoughts on it.. Previously..
Post #186171 2nd May 2013 12:22pm
AMD
I bet you will buy one on the 16th May Laughing Current MY2020
Gone: 1 x L405 and 2 x L322's
Post #186219 2nd May 2013 5:33pm
Phil.
Try a back-to-back test in a late low mileage 4.4 TDV8 L322 of a similar spec for £50k less and I know which one you will buy to replace your 3.6. MY23 D350 HSE
On my 7th RR plus various other JLR vehicles
Post #186580 4th May 2013 8:12pm
Vogue
This might be a stupid question but what's the difference between an SDV8 and a TDV8? 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #188648 16th May 2013 11:03am
Philip
2019 Range Rover Autobiography SDV8 Aintree Green
SDV8 is what it's called in the L405, little bit more power, same torque (presumably because of the gearbox rating), but no fundamental changes as far as I'm aware.
Post #188662 16th May 2013 11:54am
Phil.
The SDV8 sounds better than the TDV8 - more V8 rumble. MY23 D350 HSE
Post #188669 16th May 2013 12:16pm
Philip
That will largely be down to the exhaust - listen to a 3.6 TDV8 in a Sport compared with the same in a proper one.
Post #188670 16th May 2013 12:21pm
Will do a write up soon, but here's a photo to keep you busy. Was an AWESOME day out in the new L405.
 Discovery 4 HSE
Post #188738 16th May 2013 7:15pm
Whats that on the top of the passenger seat side above the cubby box?? FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #188750 16th May 2013 7:39pm
Vogue
I know what the "T" stands for in TDV8 but what does the "S" stand for in SDV8? Or am I just thick? 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #188768 16th May 2013 8:26pm
If its the same as the 2010's it's the button to open the cubby box
Post #188778 16th May 2013 8:57pm
Philip
Not sure it does other than an indication that it has changed (e.g. TDV6 to higher-performance SDV6).
Post #188799 16th May 2013 10:41pm
Exactly that, twin buttons. Discovery 4 HSE
Post #188800 16th May 2013 10:43pm
Nick Ground
United Kingdom 2015 Range Rover Autobiography 5.0 SC V8 Indus Silver
Or do you mean the 'seat away' switch on the side of the seat? Allows the rear seat passenger to move the seat forward for more leg room. 2019 D5 HSE Lux SDV6 Indus
55 D3 SE
98 MX5 1.8 RS
gone 17 older variants of FFRR
Post #188895 17th May 2013 11:37am
