Home > General (L405) > Getting an SDV8 4.4 Vogue SE |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6366 |
Yes, that's right, you read it correctly.
2nd May 2013 12:09pm |
AMD Member Since: 16 Jul 2010 Location: The South Posts: 811 |
I bet you will buy one on the 16th May Current MY2020
2nd May 2013 5:33pm |
Phil. Member Since: 19 Apr 2010 Location: West Midlands Posts: 784 |
Try a back-to-back test in a late low mileage 4.4 TDV8 L322 of a similar spec for £50k less and I know which one you will buy to replace your 3.6. MY23 D350 HSE
4th May 2013 8:12pm |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3742 |
This might be a stupid question but what's the difference between an SDV8 and a TDV8? 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
16th May 2013 11:03am |
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2564 |
SDV8 is what it's called in the L405, little bit more power, same torque (presumably because of the gearbox rating), but no fundamental changes as far as I'm aware. |
16th May 2013 11:54am |
The SDV8 sounds better than the TDV8 - more V8 rumble. MY23 D350 HSE
16th May 2013 12:16pm |
That will largely be down to the exhaust - listen to a 3.6 TDV8 in a Sport compared with the same in a proper one. |
16th May 2013 12:21pm |
Will do a write up soon, but here's a photo to keep you busy. Was an AWESOME day out in the new L405.
16th May 2013 7:15pm |
Whats that on the top of the passenger seat side above the cubby box?? FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
16th May 2013 7:39pm |
I know what the "T" stands for in TDV8 but what does the "S" stand for in SDV8? Or am I just thick? 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
16th May 2013 8:26pm |
If its the same as the 2010's it's the button to open the cubby box |
16th May 2013 8:57pm |
Not sure it does other than an indication that it has changed (e.g. TDV6 to higher-performance SDV6). |
16th May 2013 10:41pm |
Exactly that, twin buttons. Discovery 4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 Hard Top *Gone:L462 D5 HSE LUX, L663 Defender 110 HSE, Discovery 3 HSE, 2014MY Range Rover Sport 5.0 Supercharged AB Dynamic; L405 Exec Vogue SE 4.4, 5.0 Supercharged Autobiography, Defender TDCi XS CSW, Defender TD5 HT, Vogue SE TDV8, Vogue TD6, RRSport SC 4.2V8, Classic 3.9 Vogue Auto, Land Rover Series 3 SWB |
16th May 2013 10:43pm |
Nick Ground Member Since: 27 Dec 2011 Location: Dorset Posts: 584 |
Or do you mean the 'seat away' switch on the side of the seat? Allows the rear seat passenger to move the seat forward for more leg room. 2019 D5 HSE Lux SDV6 Indus
17th May 2013 11:37am |
