Home > In Car Electronics (L322) > Cd changer gone 2005 54 l322 "no disk" |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3754 |
Have you disconnected the battery for 30 minutes? This can clear loads of problems including suspension faults 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
16th May 2013 7:01am |
DTaylor Member Since: 15 May 2013 Location: Manchester Posts: 163 |
I havnt as i knew the changer was gone, i tried taking it apart to see if anything was stuck but nothing would move inside, i fancied an update anyway, cd changers seem really old tech.
16th May 2013 7:09am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16306 |
Welcome, you may be aware of Dension ipod kits? Well the only way you can buy such a thing is to purchase one through Land Rover as they have them made under licence... They are called an iPod Connectivity Kit and are around £400... They are sold for the 2007> facelift model onwards but fit from the earliest touchscreen models (as they have the same tech) I have one in my "55" plate and they are great
16th May 2013 7:29am |
Interestingly Land Rover is not included on the Denison Website at all... |
16th May 2013 7:38am |
Must have paid a bit for that exclusivity as just about every other Brand is on their website |
16th May 2013 7:43am |
Yes Gaz, thats why they cost a small fortune |
16th May 2013 7:44am |
Is there a way of fitting it and keeping the CD changer unit as well? |
16th May 2013 7:46am |
Yes Gaz, they have a button in the glovebox (with a USB) you need to turn the car off switch the button and the CD if back as primary, then visa versa to go back to iPod...
16th May 2013 7:53am |
Sounds very good. And the price from Land Rover? |
16th May 2013 7:56am |
Found this for Forum info:
16th May 2013 7:59am |
[/i][/u] |
OK I did see that but assumed that was your fitted price. I have seen them advertised for £165....
16th May 2013 8:04am |
Would this work with the touchscreen model?
16th May 2013 8:15am |
I would presume thats for the early non touch screen... |
16th May 2013 8:19am |
