![]() | Home > In Car Electronics (L322) > Cd changer gone 2005 54 l322 "no disk" |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3754 ![]() ![]() |
Have you disconnected the battery for 30 minutes? This can clear loads of problems including suspension faults 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
DTaylor Member Since: 15 May 2013 Location: Manchester Posts: 163 ![]() ![]() ![]() |
I havnt as i knew the changer was gone, i tried taking it apart to see if anything was stuck but nothing would move inside, i fancied an update anyway, cd changers seem really old tech.
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16306 ![]() ![]() ![]() |
Welcome, you may be aware of Dension ipod kits? Well the only way you can buy such a thing is to purchase one through Land Rover as they have them made under licence... They are called an iPod Connectivity Kit and are around £400... They are sold for the 2007> facelift model onwards but fit from the earliest touchscreen models (as they have the same tech) I have one in my "55" plate and they are great |
Interestingly Land Rover is not included on the Denison Website at all... |
Must have paid a bit for that exclusivity as just about every other Brand is on their website |
Yes Gaz, thats why they cost a small fortune |
Is there a way of fitting it and keeping the CD changer unit as well? |
Yes Gaz, they have a button in the glovebox (with a USB) you need to turn the car off switch the button and the CD if back as primary, then visa versa to go back to iPod...
Sounds very good. And the price from Land Rover? |
Found this for Forum info:
OK I did see that but assumed that was your fitted price. I have seen them advertised for £165.... |
Would this work with the touchscreen model?
I would presume thats for the early non touch screen... |
