Home > Maintenance & Mods (L322) > Door mirror cover
RRBlue
England 2005 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
Door mirror cover
I have been struggling to remove the main cover from my door mirror so that I can paint it.
I have a late 2005 4.2 s/c and have tried inserting a pallet knife between the main cover and the rectangular glass surround.
The surround comes free but that is as far as it goes. No sign of the main cover coming loose.
Can someone point, me in the right direction?
Post #187839 12th May 2013 7:10am
Picture so we can see what type you have? (always tricky @ 2005 Wink) .
Post #187856 12th May 2013 9:30am
RRBlue
Once I have worked out how to cut and paste photos in here from my ipad I will oblige.[/img]
Post #187874 12th May 2013 12:03pm
Like this?
if so follow this:
http://www.fullfatrr.com/gallery/thumbnails.php?album=341 .
Post #187889 12th May 2013 2:02pm
Re: Door mirror cover
You are struggling because they don't come off... They are plastic welded together...
Post #187903 12th May 2013 3:41pm
RRBlue
I have seen these photos and they look the same except my light is rectangular
Post #187912 12th May 2013 4:54pm
Yawn Banging Head Whistle
Post #187917 12th May 2013 5:18pm
RRBlue
Not sure what you mean Craig. The rectangular surround comes off quite easily. It appears that the main body, which is all in one piece, unlike others which are split half way up, can not be removed without detaching and dismantling the whole mirror assembly.
Post #187925 12th May 2013 5:48pm
If it is the same as mine (original '02 > ) then the main cover (the big bit) should just fall off IIRC as it is only held on by the ring @ the mirror.
However, could be as Cam tech Craig says, and though looking the same as mine, is in fact a different design ??? .
Post #187945 12th May 2013 7:29pm
RRBlue
Post #187985 13th May 2013 6:01am
RRBlue
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated :mrgreen:
Post #187986 13th May 2013 6:18am
Flashman
England 2011 Range Rover Autobiography TDV8 Santorini Black
Mine are like that and I don't think it is an easy job to remove the casing. It seems to be screwed/bonded in place from inside. Land Rover sell the covers that stick on top of them, and they work very well I bought some Java Black ones from Duckworths.
Other than that, mask off the parts you don't want painted sand, prime, paint and clear coat the part while on the vehicle. Tom
Current Drive
2011 4.4 TDV8 Autobiography - Santorini Black - Ivory Leather
Previous Drives
2004 Model Vogue Td6 (Touchscreen) - Java Black - Parchment Leather
1994 RR Classic 3.9 V8 Soft dash - Niagara Grey - Grey Leather
1972 Series III SWB Safari - Green (Hand Painted) - Black Plastic
Post #188035 13th May 2013 1:48pm
All the good FF's came factory fitted with the body coloured covers Wink FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #188038 13th May 2013 2:10pm
NOT the same as mine Confused .
Post #188130 13th May 2013 8:08pm
As I said, you have a facelift car with later mirrors that are not designed to come apart as they are plastic welded together in the factory... Rolling Eyes
Post #188150 13th May 2013 9:40pm
