Home > Maintenance & Mods (L322) > Door mirror cover |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6409 |
Picture so we can see what type you have? (always tricky @ 2005 ) .
12th May 2013 9:30am |
RRBlue Member Since: 23 Feb 2012 Location: Cambs Posts: 222 |
Once I have worked out how to cut and paste photos in here from my ipad I will oblige.[/img] |
12th May 2013 12:03pm |
Like this?
12th May 2013 2:02pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16298 |
You are struggling because they don't come off... They are plastic welded together... |
12th May 2013 3:41pm |
I have seen these photos and they look the same except my light is rectangular |
12th May 2013 4:54pm |
12th May 2013 5:18pm |
Not sure what you mean Craig. The rectangular surround comes off quite easily. It appears that the main body, which is all in one piece, unlike others which are split half way up, can not be removed without detaching and dismantling the whole mirror assembly. |
12th May 2013 5:48pm |
If it is the same as mine (original '02 > ) then the main cover (the big bit) should just fall off IIRC as it is only held on by the ring @ the mirror.
12th May 2013 7:29pm |
13th May 2013 6:01am |
13th May 2013 6:18am |
Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1228 |
Mine are like that and I don't think it is an easy job to remove the casing. It seems to be screwed/bonded in place from inside. Land Rover sell the covers that stick on top of them, and they work very well I bought some Java Black ones from Duckworths.
13th May 2013 1:48pm |
All the good FF's came factory fitted with the body coloured covers FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
13th May 2013 2:10pm |
NOT the same as mine .
13th May 2013 8:08pm |
As I said, you have a facelift car with later mirrors that are not designed to come apart as they are plastic welded together in the factory... |
13th May 2013 9:40pm |
