Home > Technical (L322) > Welding to exhaust. Electrics!! |
oliver9627 Member Since: 25 Oct 2012 Location: Chipping Norton Posts: 51 |
My 2004 4.4 v8 exhaust/CAT is popping/blowing a bit when cold. when it warms up it stops. I need to do a little bit of Mig welding.
11th May 2013 10:15am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3967 |
You could isolate the exhaust from the car by removing the engine earth strap, the exhaust is then on isolating rubber mountings.
11th May 2013 10:37am |
thank you.
11th May 2013 10:46am |
Set multimeter to the resistance scale.
11th May 2013 10:49am |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7916 |
On my meter, the reading should be infinity for an open circuit - zero means it's a perfect connection...... |
11th May 2013 11:13am |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6407 |
Exhaust removal (well on TD6 anyway) is pretty straight forward, so would make working on it much easier to do this. .
11th May 2013 11:17am |
TheAllSeeingPie Member Since: 18 Apr 2012 Location: Leeds Posts: 848 |
On a 4.4 the exhaust is all one piece and has pre and post cat sensors, which talk to the main engine ECU. You'll need to disconnect those or the mig will fry them and your ECU. If the hole isn't too large I'd probably just get some Loctite High Temp silicone sealant on it. Otherwise I'm sure a garage will weld it up for not too much. An hours labour is cheaper than a load of new ECU's.
11th May 2013 12:05pm |
Pfazz Member Since: 07 Apr 2012 Location: Stalybridge, Cheshire. Posts: 507 |
Disconnecting earth straps and relying on rubber mounts to insulate away from a circuit path is fraught with danger, once you find out you have fried an ecu it's too late. Gas welding is your friend in this situation. Agueroooooooooo. 93-20
11th May 2013 1:03pm |
Unfortunately gas welding is a skill that seems to become lost. My dad (7 can still do it (he did many exhaust and frame repairs on my old bangers) but I doubt whether he will want to fly over to the UK to do it
11th May 2013 2:00pm |
Thank you for all the replies.
11th May 2013 2:17pm |
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 |
Informative thread
11th May 2013 8:38pm |
ECU = Electronic Control Unit. They are little computers that do stuff like make the spark plugs spark at differing times, or the injectors change the fuelling depending on information they receive from other places (o2 / knock sensors, throttle pedal, air temp sensor). They control almost everything electrical on the car and are vital to it's operation.
11th May 2013 8:58pm |
You are quite right about unplugging and leaving dumb metal but how do you prove everything is isolated before applying a current in the form of welding? Sometimes it's worse to apply a voltage to ones side of a circuit because there is no complete circuit to control the voltage, no reference if you like makes a voltage unstable and can result in damage to electronic circuitry even at low voltages. Better safe than costly. Agueroooooooooo. 93-20
11th May 2013 9:17pm |
Budgie Member Since: 09 Jul 2012 Location: Stornoway Posts: 267 |
On my own 4.4 there's an earth strap on each exhaust rubber mounting as well. So they would all have to come off. |
12th May 2013 12:30am |
