People without knowledge sometimes offer advice.
This is often advice without knowledge.
It is irrelevent whether you disconnect the battery or not.
What is important is the earth path.
When you wish to electric weld, it is vital that the earth connection for the welder is directly onto the part you wish to weld.
This ensures that the current path is only via the part to the welding electrode.
Keeping the battery connected may reduce the possibility of electrical damage, since it limits the magnitude of any induced spikes.
disconnecting batteries can cause more problems than its worth, lost radio codes , windows, sunroofs, alarms ,drive parameters, and adaptive learn stuff losing thier programs.
If you are worried use a surge protector across the battery.
