Home > Technical (L322) > Got a stiffy?
andyboy
Wales 2004 Range Rover Vogue Td6 Java Black
Got a stiffy?
hi everybody, i have an intermittent problem, no i don't need viagra before someone makes a comment, no and again after starting the engine the steering has gone stiff, but if i turn the engine off and restart its all ok. have any of you guys had any similar issues not the viagra ha ha. or is this an early warning to something nasty Any advice would be greatly appreciated,
Regards Andy. Thumbs Up gone fishin'
Post #187447 9th May 2013 3:13pm
Most likely the servotronic valve needs replacing (Reasonably cheap) but it can be a few other things too.
The re-starting solution indicates a sticky valve. I have similar on my 2004 touchscreen facelift and keep meaning to swap out the Servotronic Valve.
Plenty on here to search and digest on the issue. Thumbs Up
Post #187452 9th May 2013 3:18pm
andyboy
Thanks Gaz, how cheap is cheap? gone fishin'
Post #187454 9th May 2013 3:21pm
I think the Valve is about £80 and should be 30-60 minutes at an Indy.
Post #187457 9th May 2013 3:22pm
dave.s
mine has done this on and off for the last 2 years.
also when unlocking with remote sometimes front doors
unlocks, rears dont. start car and unlock all doors via
dash lock, steering then goes stiff and have to restart.
given up worrying about it now. another rr quirk
dave
Post #187460 9th May 2013 3:28pm
andyboy
Once again thanks Gaz Bow down gone fishin'
Post #187461 9th May 2013 3:28pm
dave
that could be the BCM....
Post #187462 9th May 2013 3:31pm
dave.s
hi gaz, it can be very intermittant, sometimes perfect for
2/3 months then plays up for a few days. is the bcm
a pricey job.
dave
Post #187468 9th May 2013 3:40pm
I think its only about £90/100 and cannot be that much to fit/replace but I am not sure.
Post #187476 9th May 2013 4:34pm
dave.s
thanks for that ,did a few serches and seems quite
easy to do.
dave
Post #187489 9th May 2013 5:51pm
Post #187492 9th May 2013 6:11pm
