Home > Maintenance & Mods (L322) > Facelift rear bumper
Rich86
United Kingdom 2009 Range Rover Vogue TDV8 Nara Bronze
Can anyone tell me what the difference is with pre-2010 rear bumpers versus the later ones?
Is it only the size of the holes for the parking sensors?
Thanks. 2009 Vogue TDV8 Nara Bronze
2002 Vogue V8 Zambezi Silver
1986 90 Pick up Deep Bronze Green
1978 Series III SWB Deep Bronze Green
Post #187225 8th May 2013 3:31pm
Rich86
Come on guys, someone on here must know the answer.
Post #187283 8th May 2013 7:53pm
4 hours....i'd wait a bit longer for an answer if you have the patience.. ... - .- -.
Post #187284 8th May 2013 7:56pm
Rich86
Thanks Stan...I don't think there is much difference to be honest.
Post #187295 8th May 2013 8:39pm
Stryke
United Kingdom 2006 Range Rover Vogue SE Supercharged Java Black
Have a look at photos and compare the two ie pre 09 and post.
Main difference is that the facelift bumper uses the newer smaller type parking sensors.
Post #187308 8th May 2013 9:45pm
Parking sensor holders are now molded into the bumpers rather then removable so unless you want to replace the PDC sensors with 2009> units and rewire them..... Thumbs Up
Post #187315 8th May 2013 10:07pm
Rich86
If I facelift the front to 2010 then this will mean smaller type PDCs so I was thinking the rear would probably look odd with the older type.
So the only solution to make them match would surely be to fit the later type bumper and fit the later PDCs?
Post #187334 9th May 2013 6:50am
Really! Have you not looked at the similarities then? You would do well to tell them apart from the PDC sensors my friend... Better off spending the money elsewhere IMHO... Rolling Eyes
Post #187360 9th May 2013 9:13am
Rich86
Maybe so... 2009 Vogue TDV8 Nara Bronze
Post #187365 9th May 2013 9:42am
Stryke
Ye, a bit of a waste of money if you ask me. Nobody is going to look at your front sensors, remember their size then run to the rear of the car and tell you they are slightly larger... Rolling with laughter
Post #187380 9th May 2013 10:20am
Don't do it! Surprised
Post #187381 9th May 2013 10:21am
Rich86
Ok guys I'm convinced Laughing 2009 Vogue TDV8 Nara Bronze
Post #187444 9th May 2013 3:09pm
Rich86
Ok so I need to replace my existing original PDCs and was wondering whether I should order original replacements or whether the newer ones can be retro fitted without much hassle.
I prefer the look of the later ones as they look slightly more aesthetic and also they may be more reliable?
Suppose the question is do the newer PDCs fit the older bumper recesses without modification and likewise with the wiring. Are the newer ones plug and play with the older type wiring harness?
If its reasonably straightforward to do then I will acquire the newer type. 2009 Vogue TDV8 Nara Bronze
Post #189754 22nd May 2013 7:35am
06 onwards or are you still on about 10my onwards?
Post #189767 22nd May 2013 7:55am
Stryke
The 2010 PDCs will not fit the 02-09 rear bumper.
They are not plug and play as the plugs are different on the new PDCs...
Post #189834 22nd May 2013 1:12pm
