![]() | Home > Maintenance & Mods (L322) > Facelift rear bumper |
Rich86 Member Since: 10 Mar 2013 Location: Surrey Posts: 509 ![]() ![]() ![]() |
Come on guys, someone on here must know the answer.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35510 ![]() ![]() |
4 hours....i'd wait a bit longer for an answer if you have the patience.. ... - .- -.
Thanks Stan...I don't think there is much difference to be honest.
Stryke Member Since: 16 Nov 2010 Location: UK Posts: 262 ![]() ![]() ![]() |
Have a look at photos and compare the two ie pre 09 and post.
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16315 ![]() ![]() ![]() |
Parking sensor holders are now molded into the bumpers rather then removable so unless you want to replace the PDC sensors with 2009> units and rewire them..... |
If I facelift the front to 2010 then this will mean smaller type PDCs so I was thinking the rear would probably look odd with the older type.
Really! Have you not looked at the similarities then? You would do well to tell them apart from the PDC sensors my friend... Better off spending the money elsewhere IMHO... |
Maybe so... 2009 Vogue TDV8 Nara Bronze
Ye, a bit of a waste of money if you ask me. Nobody is going to look at your front sensors, remember their size then run to the rear of the car and tell you they are slightly larger... |
Don't do it! |
Ok guys I'm convinced |
Ok so I need to replace my existing original PDCs and was wondering whether I should order original replacements or whether the newer ones can be retro fitted without much hassle.
06 onwards or are you still on about 10my onwards? |
The 2010 PDCs will not fit the 02-09 rear bumper.
