![]() | Home > Maintenance & Mods (L322) > 4.4 V8 rocker cover gaskets |
Deasy Member Since: 26 Oct 2011 Location: Warwickshire Posts: 210 ![]() ![]() ![]() |
Hmmmm, why are range rovers so needy???
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 ![]() ![]() ![]() |
Mine were a bit random. I knew they always had a weep, but took it for an LPG service and the guy said he had a massive pool under the car from a leek |
I'm guessing that's what originally made mine weep rob. But iv done the pcv valve and hoses
They are rubber yes BUT if your going to the effort of removing them to check I would just replace them. The worst area i think is the back of the gasket. There is a big half circle that's filled with the gasket. Only reason I can think of is to get the cam shafts in or something like that. If there's no reason it's |
Ok il give that ago as I have noticed oil around the bolt heads abit |
dirtyharry Member Since: 23 Oct 2012 Location: Ashby Magna Posts: 242 ![]() ![]() ![]() |
Well, I followed Robs' excellent instructions and attempted the passenger side first, but alas to no avail |
Yep I have the same issue, my LPG kit is right in the way! |
Glad it's not just me then! |
its a total |
This is how tight mine is!
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() ![]() |
ooooosh thats going to be tight! I struggled to get past the blend motor without the evaporator being there! All my stuff was tucked away behind the block. Made it hard to service and work on but looked good and obviously made changing the rocker easier. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Mine is not too dissimilar to Deasy's!
paneldamage Member Since: 11 Nov 2010 Location: Preston Posts: 222 ![]() ![]() |
Just done this today on my 4.4 M62, both sides, absolute pig to do the passenger side with the LPG pipe work, six hours but wasted a load of time dodging the rain, then had to take the undertray off co I dropped one of the special nuts in the bowels of the beast, plus the gasket keeps falling off- that's bl***y gravity for you- or it gets knocked off as you manoeuvre it home.... top tip, some strong elastic bands, about five of them spaced out along the cover to hold it in the groove, then just cut the bands and pull them out when the cover is nearly on.... |
It's not a pushrod engine and it's pre valvetronic so there's no actual rocker. Aren't they actually cam cover gaskets?
