Home > Maintenance & Mods (L322) > 4.4 V8 rocker cover gaskets
Page 3 of 3 <123
espaceboy
only put gasket sealer on the half moons and on the front ridges as identified in RAVE
BMW actually suggest silicon lube on the rocker lips to make the gasket float and seat better. Don't think I would do that, but I would suggest using the elastic band trick (mentioned in this thread) to hold the gasket to th cover when fitting
buy OEM - its a bad enough job that you only want to do it once
fit all new gaskets and rubber washers
another useful link
http://blog.bavauto.com/12316/bmw-diy-v8-a...4-m60-m62/
Post #369318 29th Jan 2016 11:19am
Zambezi
United Kingdom 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
Thanks for the advice and the BMW link......makes it sounds quite easy Shocked
Parts ordered from Britcar.
A job for next week some time
Thumbs Up 2002 4.4 V8 with LPG
Zambezi silver
Post #369340 29th Jan 2016 12:16pm
Welshdragon
Great write up on this 👍👍, i did mine today after months waiting for some good weather but ........what a pig of a job to do the drivers side 😠.
The rubber gaskets where as hard as plastic and the washers too.
Now just hoping it doesn't leak oil any more 😆. If it dont work.......burn it!
Post #375892 5th Mar 2016 7:28pm
knares
Australia 2005 Range Rover Vogue 4.4 V8 Zambezi Silver
great post for me
I am new to this forum and the range rover so I have no idea but as regards to the rubber gasket falling out as you try to fit the cover, when building Detroit Diesels we had the same problem, to solve this we super glued a few spot around the cover to hold it in place.
This was common practice.
I like the idea of silicon grease on the head surface as esraceboy says
Just my thoughts
Post #442761 26th Jun 2017 2:27pm
Danwilderspin
What an absolute bar steward!
I went to do the driver first as it has less gas around it...
Coming off was fine, going back on how do you check the top semi circle is in? I could feel the bottom - I’ve had to guess and start it and couldn’t see any leakage...
Two... those rubber washers!!! Should they be very tight? As in I had to push it together in a vice? I’m wondering if they had been sat on the shelf for a while and gone hard? I ended up for the dipstick ones reusing the old with some silicone and washers there was no other way I could get them on...
Those washers took over an hour of messing so only got one bank done today... gas on the other side so didn’t want to start
At 5pm... Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #464442 13th Jan 2018 6:18pm
24valve
United Kingdom 2010 Range Rover Autobiography Black TDV8 Santorini Black
Sometimes you wonder if anything is really easy on the range rover.
I decided to order everything I needed last week and started tackling the job yesterday. It has been a pain in the posterior getting the drivers side cover off - it took a lot of swearing to get it past the dipstick tube, injector cover and A/C pipes and I'm still not sure how it came out, but it did.
My next concern is getting it back in with the new gasket in place, but I'm going to look at the elastic band trick if I need to.
It is obvious however that the gaskets have never been changed - they literally all chipped off in lumps and almost none of it was rubbery like the new one - even the bolt washers were hard. Theres a lot of oil in the plug holes which I've cleaned up too, so fingers crossed this is going to make a real difference.
Thanks for the write up on this though - very helpful indeed.
Neil. 2010 L322 Autobiography Black Edition
1975 Land Rover
Post #581993 1st Feb 2021 1:01pm
Gsxr1250dave
I put a very small bead of rtv in the channel the gaskets sits in to keep it in place, never had an issue doing it this way.
Post #582044 1st Feb 2021 5:37pm
24valve
Thats another job off the list.
I eventually used the elastic band method on both banks, but on the passenger side I kept catching the gasket on something so it fell out of place near its destination. fortunately though on that side you can lift the cover sufficiently away to reseat the gaskets and drive it home easily. I then used a small inspection camera to ensure the gasket was seated correctly all the way around (or as much as I could see) and luckily no more leaks and no more smells. The old one was really brittle and oil was in the spark plug holes quite a bit on the passenger side.
Next up...serpentine belt and tensioner...never ends. 2010 L322 Autobiography Black Edition
1975 Land Rover
Post #582206 3rd Feb 2021 9:20am
Page 3 of 3 <123
