Home > In Car Electronics (L322) > AV In Front Screen |
Tuts Member Since: 24 May 2012 Location: Bishop’s Stortford, Herts Posts: 201 |
There are a/v leads that add an aux to the tv tuner for the BMW based ranges (search eBay for range rover aux) can't see why they can't make the same leads for the denso based tv tuners (can't see any on eBay though?) might be worth contacting the sellers of the earlier models leads? 2003 Vogue 4.4 V8 Java Black |
6th May 2013 10:32pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35293 |
http://www.disco4.com/shop/index.php?act=v...oductId=34 ... - .- -.
7th May 2013 7:25am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
Stan, the FF already has 3 fakra leads connected... |
7th May 2013 8:28am |
Speak to these guys? http://www.toysinyourcar.com/acatalog/AV_I...TH_TV.html |
7th May 2013 8:30am |
not going to argue with an expert but is not one of those sockets free? [3 sockets on top right]
7th May 2013 8:33am |
No no stan... They are all taken... |
7th May 2013 8:36am |
so would that be a tv tuner, sat nav and ? ... - .- -.
7th May 2013 8:45am |
Reverse camera |
7th May 2013 8:53am |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6366 |
I was using my RSE this weekend and found the following:
7th May 2013 9:37am |
Martin Site Admin Member Since: 24 Mar 2007 Location: Hook Norton Posts: 1665 |
The 3 FAKRA composite connectors are used for:
7th May 2013 9:50am |
so its possible to utilise the venture cam input if you dont use it or the rse input if you havnt got it.. ... - .- -.
7th May 2013 9:59am |
You can see what's configured through the "753" hack diagnostic screens, oddly I think mine says that RSE isn't fitted, even though it is! Discovery 4 HSE
7th May 2013 10:06am |
Rexyboy Member Since: 04 May 2013 Location: Sydney Posts: 2 |
So far the only interface I have found is this one:
7th May 2013 10:58am |
i dont think there is anything much cheaper..its the MOST system that makes it expensive.. ... - .- -.
7th May 2013 11:00am |
