Home > Technical (L322) > Wouldn't start...
Wouldn't start...
It had been taking more and more cranking over to start when hot so I had the secondary fuel pump replaced.
Today I was at the DIY place with a trailer full of stuff and it wouldn't start. Swiss AA guy comes, there's either air or cavitation in the fuel line - you can see it. He squirts some Swiss easy start in and it fires up. Driving home I get the fuel injection system error.
I'll drive it to the garage on Monday, but either the guy who said he'd repaced the fuel pump didn't, or I have some other issue.
The really annoying thing is my other car won't start either, but that's another story.
Post #186514 4th May 2013 12:20pm
mjdronfield
I may be wrong here, just thinking aloud -
My secondary fuel pump failed a couple of weeks ago. There was no warning. Car always started first touch of the key. Hot or cold. Came out from work - just spun over, didn't fire.
The AA man that came out to me diagnosed secondary fuel pump by taking a pipe off the fuel filter under the bonnet, and turning the ignition on. (with towels around the pipe etc).
No fuel came out.
He said this tends to happen when the secondary pump goes - in his experience. If it was the pump in the tank, he said you get lumpyness, and some reluctance to rev over a certain rpm - but it does start and run.
There was also another forum member who had a non starting issue, but from after a run only, and the replacement of the secondary fuel pump didn't fix it. He's talking about crankshaft sensors etc........
Suppose what this leads me to, is that as you've had some symptoms show, such as reluctance to start etc, I'd wager its not the secondary fuel pump.
As I say, just thinking aloud- may be wrong.......
Suppose you may end up having to get the error codes off......
Hope this is some help. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #186610 5th May 2013 7:40am
There is the probability the new secondary pump has failed! Should be covered by warranty... Thumbs Up
Post #186614 5th May 2013 7:56am
Turned out to be a dodgy injector - number 1 cylinder.
I had to top up the coolant recently and the garage confirmed it has a leak - so I'm in the market for a new radiator.
Can't really complain given it's done 112k miles.
Post #186823 6th May 2013 2:28pm
Just got it back - now starting ok.
I've ordered a new radiator and also, as the car's taking an age to change height, a new compressor. But these I'll fit myself.
Post #187160 8th May 2013 7:27am
ebajema
Did you consider getting the Meerbusch compressor refurb kit ?? MY 2010 5.0 SC Galway green and sand interior!!
Post #187162 8th May 2013 7:44am
I did. He clearly knows his stuff and it looks a really good kit, but at the end of the day I don't have a lot of time available to install it. Also, I managed to find a new one for £230.
Post #187166 8th May 2013 7:57am
Re: Wouldn't start...
And I managed to get the other car started also. Dodgy connection to the fuel pump relay.
Put the wheels on my SP2 motorcycle also, so all my vehicles are coming up to scratch!
Post #187168 8th May 2013 8:17am
Congrats on getting yours back on the road Smile
Was the injector fully leaking back so bleeding the rail pressure off and leaving it unable to attain pressure at crank speeds but fine at idle? FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #187177 8th May 2013 8:45am
I didn't do the test - I took it to a garage, but yes, that was the problem.
I meant to do it myself a while ago but never got round to it, and to be fair, over winter it started ok. Bit of hot weather and it was fooked. Kicking myself a bit as a main dealer in Switzerland wasn't cheap, but I needed the car back on the road. I have a guy working on my house and I need to keep him supplied with materials, and the sports car won't tow a trailer!
Post #187181 8th May 2013 9:15am
Surely the VX could pull a little trailer Wink FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #187195 8th May 2013 10:48am
It has more power than the TD6, but where would you attach the tow bar?
It's also a seriously light car - unless you were thinking of something like this?
Post #187200 8th May 2013 11:35am
Stopped for a coffee at a cafe for half an hour, when I came back the car wouldn't start. Just a click and then nothing. Absolutely no electricity at all after that.
Swiss AA man came and we found out the battery negative terminal hadn't been connected properly.
Going to as for an L405 in compensation.
Post #188391 15th May 2013 7:34am
PMPL i'd love to see that letter Smile
And yeah you could just put loads of sandbags in the VX to weight it down Wink FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #188399 15th May 2013 9:13am
