Home > Technical (L322) > Coolant level sensor
ebajema
Gents,
I replaced the coolant level sensor a while ago but it still doesn't work properly. The old one looked slightly different from the new one with a short (2 mm) piece of metal sticking out. The new one didn't have the, it looked like it was fitted with a little cap underneath which the same piece of metal could be hiding. I didn't remove the "cap" when I installed, should I have ? MY 2010 5.0 SC Galway green and sand interior!!
Post #177904 16th Mar 2013 1:11pm
this shows a coolant sensor on a 4.4 petrol, not what you have but could it be the same? [half way down the page ]
http://www.fullfatrr.com/forum/topic16423.html ... - .- -.
Post #177908 16th Mar 2013 1:53pm
ebajema
Excellent write up but not the sensor I mean.
I am talking about the one in the bottom of the expansion tank Smile MY 2010 5.0 SC Galway green and sand interior!!
Post #177909 16th Mar 2013 1:55pm
Katash
England 2007 Range Rover Supercharged 4.2 SC V8 Zermatt Silver
You probably already know this but the level sensor also checks the SG of the coolant - I assume your mix is correct?
Post #177925 16th Mar 2013 4:15pm
EB yours might be Censored now due to the oil in the coolant? [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #177945 16th Mar 2013 6:51pm
ebajema
There was a little cap on the tip of the sensor. When the sensor blew out !!!! of the tank when the transmission oil cooler went, I looked it and pulled a tiny rubber cap off. Since then the sensor is working (with clean proper coolant that is of course). MY 2010 5.0 SC Galway green and sand interior!!
Post #186404 3rd May 2013 4:18pm
