Home > Technical (L322) > had her 2 days and already battery problems |
I seem to remember that around your model year there were a number of issues with the batteries and some cars had updates to one of the ECUs (as well as a new battery) in a recall.
2nd May 2013 9:49pm |
tboner001 Member Since: 22 Jan 2011 Location: Bucks Posts: 691 |
"battery management system" (or something like that) has been reset and that a reset is a worksop thing"
2nd May 2013 9:51pm |
Rich86 Member Since: 10 Mar 2013 Location: Surrey Posts: 509 |
Have you spoken to the last owner and asked whether he had this problem?
3rd May 2013 5:30am |
Fleagle_UK Member Since: 20 Mar 2013 Location: Cheshire Posts: 409 |
yeah - whenever the "low battery ....start engine" comes on the engine starts absolutely fine. But clearly the battery has lost its edge as you can't run any ancillaries for more than a few minutes before the message comes on so thats means it's pointless using things like park heating / venting (something I specifically wanted) as it has no chance given that they swallow so much of the battery charge. CD player / sat nav / blowers etc all cut out until engine is started.
3rd May 2013 8:30am |
IWC1 Member Since: 11 Jan 2013 Location: suffolk Posts: 18 |
To start with I recommend that you take a good look at the battery.
3rd May 2013 10:23am |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 797 |
sounds to me that you should check....you have the AGM battery
3rd May 2013 6:11pm |
The battery on the car is branded as a Varta (has a small Landrover Jaguar sticker on it). Dealer tells me that is a standard fit. Been on the car since new apparently.
3rd May 2013 7:45pm |
depending on when your MY11 rolled off the production line, it will have a standard battery or AGM type.
4th May 2013 6:14am |
Sorry for being thick, so is it generally regarded to be better to have an old fashioned battery type or an AGM ?
4th May 2013 8:13am |
The advantage of the AGM is that it is quicker to charge, and therefore more suitable for the battery management system that LR designed for the MY11 onwards, and also that it should be able to start the engine when only partially charged.
4th May 2013 11:06am |
well....dealer fitted a brand new battery. (AGM type)
17th May 2013 4:54pm |
wslr Member Since: 04 Dec 2011 Location: Wellington, Somerset Posts: 64 |
It's a bit vague as really it was the 10MY facelift models with the 3.6 which had most attention.
17th May 2013 9:15pm |
the early 4.4s had the problem
18th May 2013 5:42am |
There was a a ECU flash and a battery regulator module
18th May 2013 6:23am |
